munk said:I'd use any one of the excellent wood glues myself.
This superglue cult is starting to get to me. They use the stuff for everything, sealing cuts, finding fingerprints on materials left around a homocide victim; what next? Breakfast cereal with super glue glaze?
depending upon how bad the crack is. Remember wood needs periodic treatment to remoisturize and protect. Sealers are good.
You may chose to pin your handle at some point. Very easy- drill through handle and tang with small hole, tap in pin.
munk
aproy1101 said:Billy,
Those are both gorgeous handles that needed to have the yak skat and rouge mixture sanded off anyway. This could turn out to be a blessing. You won't believe how much character will show once you sand and Danish Oil those handles.
That there is an epoxy fix. The brand I use is Devcon 2 ton. I use it because WalMart sells it for <$3 here. Any clear one will do as long as you don't use a 5 minute epoxy. Sand the handles and save the dust. When you've got them rough sanded mix the epoxy and fill the crack. Don't mix in too much dust because your epoxy will get thick and hard to get into the crack. Maybe put some straight epoxy in the crack until you get close to the top. You want the epoxy to fill the entire void. Then rough sand again, and progress to finer and finer paper. Finally put a few (~10 min) of Watco's Danish Oil on it. If you can't get Watcos go to Ace hardware and get Minwax Antique Oil Finish. Good stuff but more $ than the Watcos ($9 vs ~$6).
