Sounds good.
Do you have pin holes drilled in the tang already?
If so, get your handle material and lay the tang on top of it, drill a hole put in a pine, drill another hole put in a pin (just loose fit). When you've got em all in, cut out that scale around the tang. Repeat that step for the other side.
Now put the two scales together without the blade, put all the pins in to line them up real well and shape the front end of the scales how you want them. Put them on the blade from time to time to check it out.
Once you have them shaped, finish the fronts so that you won't have to do any sanding on them and risk scratching the blade up.
Rough shape the scales to get the contour you want.
Now take either a countersink, or a drill bit bigger than the pin holes and lightly chamfer the top of the holes so they don't split when you peen the pins. Do this by hand, you don't need to remove much material at all.
After that, rough up the inside of the scales, and clean the tang with acetone or something to de-grease it. Use some type of 2 part epoxy and glue it all together with the pins in place. Be sure to leave the pin protruding some on both sides. Clamp it up (not too tight, you'll squeeze out all the epoxy) and let it set up.
Now file or grind the pins down so that they only stick up 1/16" an inch or so and lightly peen them.
Now go on and finish sanding the handle, don't remove too much material or you'll take the heads off the pins.
Thats the basic run down for how I do it. If you have any trouble or more specific questions let us know.
