- Jul 2, 2005
I get the steel from an outfit that makes farm impliments.1/4" thick X 1.5" wide.
I grind the details and weld the hilt in place. The hilt is made on the blade ( 4 pieces ). The steel then gets heated cherry red and shocked hard in cold , used motor oil. Then it's cleaned/ lightly polished and tempered to 350 degrees for 30 min. The handle is P.V.C. resin poured to the full tang . It passes through 1/2" holes that were drilled for that purpose. The finished handle is the same as a piece of P.V.C. pipe. Very, very strong. And it can be easily carved.
The sheath was made by an Omish Harness Maker to my specs.
Please let me know what you think.I hope to improve through your imput.
Thanks,
Mike
