- Jun 4, 2001
I smoke a turkey every year. You have to smoke it breast down. Brined for 24 hours before and basted in bacon grease half way through. You have to keep the temperature low enough and lots of moisture in the smoker to stop it from drying out. Best way to cook turkey in my opinion.
I like to use apple and pecan. What type of smoker are you using?Interesting. Will have to try it like that. I think I smoked it at higher temp for much shorter period. what type of wood did you use to smoke with?
9-10 hours @ 225 degrees should do it for you if you have a 20lb turkey.Large pellet smoker. Insulated. I can run it as low as 165 degrees. I typically do low and slow brisket for 30 plus hours. I sail through the stall, like there is no stall.
