- Oct 4, 2021
As I was doing my Venev/CGSW comparison something very odd happened. I was compensating for the very different stone thickness by measuring the angle of the rod on the knife. I followed what I think is the correct procedure of zeroing the angle cube on the clamp arm and then measuring the rod angle with the rod centered on the pivot and the stone in the middle of the blade. Fifteen degrees, bang-on, just as it was with the Venev stones. But when I started using the CGSW stone, I noticed that I was only hitting the front half of the bevel, indicating that the sharpening angle was well off. Measured again. Fifteen degrees, bang-on.
At that point I resorted to the Sharpie trick and finally arrived at an angle of 15.5° to hit the whole bevel, or a full half a degree higher than the angle I was using with the Venev's. What the...?
Just to confirm, I then switched back to a Venev stone, set the angle to 15° with the Angle Cube, and ... it was perfect. This seems impossible, so clearly I'm missing something.
Any ideas?
Any ideas?
