The gen 2 vertical rod with the fine tune adapter works perfectly fine, it is how I have mine set up. You lose the ability to use it as a stone thickness compensator if you switch to the precise angle adjuster. It can also be annoying if you need to switch to a much higher or lower angle a lot.
That being said if you only switch a degree here and there it is really nice. You eventually learn roughly how much change you get from a full turn and how much it takes to adjust half a degree and what not.
