Harbor Freight again
Larry, I'm sure to click on that link to take a peek. On your worry though, I have been running an open frame DC for a couple years and have so far had one pop and one bad pop. I am grinding a lot more simple high carbon now and I doubt the ol'girl will be with me much longer. For casual or periodic knife making - for the buck its a great budget. (I have not looked at your motor yet so I do not speak of it specifically).
EDIT: I looked. Not bad for the buck. Figure it high on the spec end. Count on about 1 1/2 horse. If that's good enough for the equpment 70 bucks new is not bad - my opinion - but figure it actually a little lower in horses than pictured. I might be wrong.
RL
I thought using compressor motors for something like a grinder was a no-no because they aren't intended to run continually. FWIW Harbor Freight has a 1HP TEFC "farm duty" motor online for $90, I think. May be a bit underpowered, but it's sealed up and is intended for machine/wood shop use.
T Blade said:
Just checked my e-mail. HF sent me this. http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=30189 Not too bad if you need a motor and you're on a budget. Though this is an open ended motor, it seems that people using this type have not reported burned up motors due to crap getting into the windings.
It's way too fast for a grinder motor, IMO. If you can't go variable speed, at least get a TEFC motor that runs at 1750 RPM.
Steve,
"Compressor motor" usually means that it has high starting and breakdown torque for hard starting applications (ie: compressors) and does not in itself signify if the motor is intended for continuous duty or not.
Regards,
Greg
RL
Roger, as you said "For casual or periodic knife making - for the buck its a great budget." As that is the type of grinding I perform, it's OK. I have a DC treadmill motor on my grinder (1 1/2HP maybe), and it works fine.
Mike, those are my feeling exactly. The treadmill motor I have on my grinder, operates at 4000RPM, so I am using a 2 5/8" pulley on the motor and a 5 1/4" pulley on the grinder shaft, which should cut the RPM in half, and give you more torque at the platen/wheel.
AT this time, I am not actually looking for an electric motor, I just put this up on the forum incase other newbies want to get into a grinder for less money. As some people could use an inexpensive motor, sell a couple of knives, save that money and upgrade to a more serious motor.
Larry T
Member of NECKA & NCCA
