I've used it on balsa and the resulting edge is near mirror, so it has to be fairly fine. 5-8000 grit jis, I'd estimate.
Don't worry, I know that, haha. I'm trying to figure out if I have something in the 3um range.Bill DeShivs said:As a rule, black compound is emery-a coarse, cutting compound.
Green, white, or red will be much finer.
The others I mentioned all leave a satin finish, even on a fairly soft backing. To be near mirror I'd say your first guess is close, 3u or so.
Those descriptions very closely mimic what I've seen in the black 'Emery' compound I've been using, from Ryobi, and labelled at 1-3 microns. Works very fast and leaves a very near-mirror finish. I've used it on leather and paper-over-wood, with similar results (faster on harder backing). I don't know if it's even available from them anymore, as the Ryobi that HH has mentioned in the past sounds coarser, and Ryobi's packaging (at least) is different nowadays. I recently picked up a tube of Sears' black, and it does seem coarser in finish, maybe approximating the 'satin' described by HH. Interestingly, when reading this thread and looking online at Harbor Freight's online listings, their packaging (plastic tube) looks identical to the stuff I found at Sears, sourced from China, as I assume the HF stuff is. Priced about the same, too. Makes me wonder if Sears and HF may be sourcing it from the same supplier.
David
