Hard-chrome steel platen
t1mpani
Platinum Member
I'm sorry if this has been covered before, I couldn't find it if it was, but I was just curious if anyone had tried industrial hard-chroming a steel platen. I am aware of the glass platens, but the fact that even the makers of them warn you that "this thing could fly apart at any time, sending shards of glass out in all directions" kind of gives me pause. Having had plenty of luck with hard-chromed firearms over the years (both the internal wear points and also being basically immune to kydex holsters which mark the hell out of other finishes) my thought was it might be a good way to reduce the coefficient of friction without introducing a very fragile structure into a high-speed operating environment. I have a couple guns I was considering getting chromed, figured I could remove my flat grinding platen and put it in the box too...
I don't think the plating would hold up very long.
HC is about 72 Rockwell. You could just use steel hardened and tempered just slightly to keep it from being too brittle.
I know of at least one company that hard chrome radius platen. Not sure how well they hold up compared to unplated hardened ones.
Ah yes, the Behnke platen. I remember looking at those but the hole spacing wasn’t right for my setup. Interesting, though…my whole thought is that the coefficient of friction is so much less than bare steel that the belt would have a hard time wearing it, but I could be very wrong.
Edit to add: it may just be internet rumor, but some bladesmiths have reported cracking in the glass platens over time, and there have been some comments about what would happen if/when the belt pulled a piece off and then slammed it into the lower pulley wheel at high velocity.
I never had an issue with cracking on a tempered glass platen...but with wear. I use a carbide flat platen now and love it.
Ditto
My glass platen lasted maybe 3 month?
I was dishing it out. Sucks.
I grind with ceramic belts. High hardness steels with High, Hard carbide volumes. Post heat treating.
Now, I use a Carbide platen. I Love it. Want to buy another
I don't believe regular hard steel, chromed would last long
Where are you finding carbide platens? I looked and looked…is my google-fu THAT weak?! I found links for them but they’re all sold out.
I replaced a glass platen which I chipped when mounting my work rest long ago. A small chip at the edge of the platen right at the height of the work rest was a huge pain in the ass.
The carbide platen that's on there now has been a huge improvement- no static electricity anymore, either, which is kind of game changing even though it doesn't seem like that big a deal
I chipped edges on my glass platens, so I went with carbide. I have a plain carbide one that isn't polished from online (just a carbide blank really). I smoothed it out a bit and can use it for roughing. I got one of RD_knives RD_knives . So much nicer! Already polished and holds up to everything I throw at it!! Well worth it!
I use a magnetic platen face and one of my glass platens slipped off the magnets, hit the contact wheel, travelled around and hit the drive and tracking wheel, gouging both. Found it in my shop a few months later, glass was cracked but still stuck onto the 3/8" thick mild steel backer with JB Weld.
Where can one of these carbide platens from RD-knives be ordered? I type in RD-knives but can't seem to find his web site or a place to order one of his platens.
Contact him here on the forum. He has advertised flat and CURVED carbide platens in the knifemakers for sale section.
I posted his bladeforums link above
Isn't Contender doing carbide platens as well? He's stateside.
Darren also sells the carbide platens from me. So same quality and if your looking for just the carbide itself you can get it from him aswell.
If you would like it made on a baseplate to fit your machine you can sent me an message for that.
