High Hardness
Electro-deposited Chrome is extremely hard, with typical values of 850 - 1050 HV (63 - 70 HRc), hence the term "Hard" Chrome. This makes it an excellent coating for wear resistant and abrasion resistant applications such as Moulds and Dies, Punches, Bearing and Seal surfaces, and sliding components.
Low Coefficient of fricton
Hard Chrome has a very low coefficient of friction, approx. one half that of Steel. The coefficient against Steel of 0.16 lubricated (0.21 dry), makes it ideally suited for such applications as Bearing and Seal surfaces, and machinery components.
Wear Resistance
The high hardness and low frictional properties of Hard Chrome provide it with extremely good resistance to abrasive and erosive wear, extending the life of components such as Moulds, Dies and Punches etc, up to ten times in most cases.
Corrosion Resistance
Hard Chrome has an extremely high resistance to atmospheric oxidation, and a good resistance to most oxidising and reducing agents.(with the exception to Chlorides and other Halides), hence its wide-spread use in the Food and Chemical Industries.
Sacrificial Wear Layer
Since Hard Chrome deposits are readily removed with chemical strippers, without detrimental effect to the base material, the part can be stripped and re-plated repeatedly, when wear shows, without loss or damage to the base part. This is a significant advantage for high wear, high cost parts such as Plastic Moulds and Dies where abrasive filled plastics are used.
Machining
Hard Chrome deposits can be successfully finished by grinding, linishing or polishing.
Applications
Hydraulic and Pneumatic Piston Rods and Cylinders
Plastic and Rubber Rolls, Moulds, Dies, Screws, etc.
Automotive and Mechanical components
Press Tools and Punches
Print Cylinders and Plates
Food Machinery
Valves, Gates and Bodies
Mining Equipment
Timber and Paper Processing Equipment
Pump Shafts and Rotors
Textile Components
