Thank you, David!
I apologize if my previous post seemed a bit hasty. I would like to expand on why continually opening a knife by
hard flicking might damage it:
Let's look at this from a physics/metalurgical/mechanical engineering perspective:
1. It is well known that a chain always breaks at its weakest link. With many knives, the blade is the hardest part. (This is especially true of liner-locks, which many times use spring temper stainless steel or titanium locks.)
OK: Pins, stops, and locks
could be made of similar materials of similar hardness, depending on the design. But, if they are secured by weaker materials (like zytel, G-10, etc.) they still could shift enough to ruin any chance of precise lock-up.
2. Look at the blade. Does anybody make a knife that
never needs sharpening? Sure, blade material is hard - but
most knives on the market need sharpening at some time.
3. Most folder blades are made of one material and are not differentially heat treated. This means that any area of the blade has the same hardness as the edge.
4. If the edge of a blade can wear, other areas on the blade can wear.
5. You can compensate for wear by making parts thicker so the contact areas wear less. Therefore, one could speculate that frame locks with thick blades resist wear better than liner-locks with relatively thin locks and thin blades.
6. However, the inertia exerted on a large (heavy) blade - via the "flipping" action - can increase the chance of premature wear due to the increased force exerted on the parts in contact. (ie: You can drive a nail farther faster with a bigger hammer.)
David has made an excellent point in that "flipping" a folding knife in public can get you in big trouble. (Please also read the thread concerning CRKT's issue with U.S. customs regarding "gravity knives.")
Realizing that a lot of the development of "tactical" folders continues to revolve around the lock security, I know of no maker or manufacturer who currently guarantees their folding knives will hold up to continual, hard "flicking".
With these things in mind, you need to determine how important it is for you to be able to open a knife rapidly and weigh the consequences of it wearing out faster than if opened normally.
(I believe the "social" consequences have been addressed adequately in this and the referenced threads.
Tom Anderson
Hand Crafted Knives
www.andersoncustomknives.com
[This message has been edited by Tom Anderson (edited 05-16-2001).]
