Hard Use Test: Buck Marksman
Hey guys,
I finally did a hard use test on the Buck Marksman. I was Impressed.
The only bad thing is, my camera didnt record....
So I did some photos after the test, you will find them below.
What I did: I tested the sharpness, cut an apple and paper. I cut this huge stick in half that was at least 10 cm thick and I batoned trough the same stick.
Then the pivot got loose and bladeplay appeared. I could fix that with an allan key. Later on the strap bend, so I took it appart and switched the sides.
No bladeplay what so ever. Later I noticed that I lost one screw ( you can see all that in the pictures)
But then I tested the sharpness again on paper it was still ridicilously sharp.
This knife is a beast.
If you dont believe me please write me and I will give my best and try to recreate the test.
SO what do you think about all of this?
Photos:
http://gyazo.com/3888327bc7014e1bd0cd25d4abcbd4f1
http://gyazo.com/4b054bada9bed276915d2f54255c712f
