Hello all this is my first post on the form so plz give a guy a break if I cut threw any red tape.
so I’m looking for some wisdom and guidance on hardwood handle construction and am hoping to get pointed in a better direction then where I’m at now.
so the issue I am having is that after I get a handle all together and sanded, I’ll say about 2-3 weeks later it seems that the wood on one side flex’s/curls and pulls the liner away from the tang of the knife, but never the separates wood from liner. This only seems to happen on the knives I use g-10 liners on, all the fiber liner knives seem to hold. And it usually separates on the top on one scale and on the bottom of the other, these are full tang knives FYI. So this leads me to think when I cut a block in half and turn the insides to the out side for a book Matched look , the natural grain of the wool wanting to flex/crown is causing the top and bottom separating issue. But ya just wounding if anyone else has had this same issue and found a solution to this problem any insight would be greatly appreciated.
and a lil info to let you guy know what I’m working with. I use a wide array of hard/natural woods bacote,rosewood,zebra,cocobola,Vera wood,ziricote and more. I use g-flex epoxy and I rough everything with a 120grit before glue. I mostly use corby bolts as my fasteners and I use a danish oil as my finish on the wood, also I do drill holes thru the tang and in back Side of scales to make voids for epoxy
I thank you for any help and constructive criticism
thanks,
Dillon
thanks,
Dillon
