I'm feeling pretty discouraged and frustrated tonight. This subject has been brought up before but I want to explore it a little more for the sake of my personal sanity. (Yea, I know, too late for that!)
The problem
I bought some 1080 steel from one of the popular steel suppliers to the forum. When I tried to use my hacksaw to cut it I could only cut a little way and then nothing. When I tried to drill holes in it the bits would go just a little way into the surface and then they stopped penetrating. It seems as if there is an outside layer of soft metal and an inner core or hardened steel. My best guess is that perhaps it was cold rolled and became work hardened. Can someone please tell me what is causing this frustrating situation?
Solutions
Previous solutions included Buy a high tension hacksaw. I bought one. It does work better than a regular hacksaw and Im glad I have it. (Cant have to many toys, er, I mean tools) Unfortunately I had no better luck at cutting the 1080 with it than I did with my old low tension hacksaw.
Another solution was to use carbide drill bits when I need to make holes in it. I see that Jantz sells them starting at $12 for a SINGLE BIT! OUCH! Most of the bits are $14 - $16 per bit. But the 1/4 bit is going for $30. I was at our local Fleet Farm store today and though they carry lots of tools they did not have carbide drill bits. I need to look around some more and see if I can find good bits for a reasonable price.
A third solution was to anneal it by bringing it up to a certain temperature and then slowly cool it by just leaving it in the kiln/oven. If I had an electric kiln/oven that is what I would do, but it seems a little excessive to have to spend $1,000 to anneal $100 worth of steel.
Non-solutions
Soooooo I was thinking, What if I experimented and put a piece of the steel in my kitchen oven and just let it sit there in the back where no one will mess with it, and let it go through multiple tempering sessions? After sitting in there for about a month it emerged with interesting oxidation colors on it but I still could not cut nor drill it. There was no significant change.
OK, no more Mr. Nice Guy. Out came the propane torch. As I heated the steel I saw a dark blue color appear on the cleaned surfaces but I kept on heating it, and the dark blue went away. For some reason this seemed significant to me and I stopped heating the steel when the dark blue disappeared and I let the steel air-cool. I was pretty confident that this would work. Nope. Shot down again! Maybe it was a little bit softer, but not much.
My next plan is to treat it like softening an old file. I will build a fire, heat the steel in it and let the fire die down slowly with the steel remaining buried in the ashes to slowly cool. At this point Im having doubts that this will work, given the string of failures Ive had so far.
Summary
I feel very discouraged and frustrated. Im not trying for fully shperodized or annealed steel, just soft enough to be able to work it with NORMAL tools. Is this unreasonable of me to expect? If I were tooling special aerospace materials for critical applications it would be one thing. I just want to make some knives. What Have I done wrong? What else can I try?
I feel very discouraged and frustrated. Am I going to have to jump through these same hoops every time I get steel? This is going to turn into expensive steel if I have to take it somewhere for annealing. Is there NOTHING that can be done without a kiln?
Did I mention that I feel very discouraged and frustrated?
"Help me Obiwan, You're my only hope!"
Yours in frustration,
- LonePine
Alias Paul Meske, Wisconsin
The problem
Solutions
Non-solutions
Summary
- LonePine
