I am having a problem hardening a blade i've forged from what is purportedly 9260, which i purchased from Admiral Steel.
I will freely admit to being a novice, so take all of this with a grain of salt.
Basically, I seem to be unable to satisfactorily harden my blade. Cutting into 2x4 produces tiny dings and rolls (the rolls indicate to me that it is not too hard...it doesn't seem to be chipping) in the hair-shaving sharp edge.
As 9260 is an oil hardening steel, i first attempted a quench in vegetable oil. I slowly heated my blade to critical (measured carefully several times with a magnet...bringing up to critical and then cooling to room-temp, just so i had a good idea of what critical looked like), soaked at heat for about a minute, then quenched in room temp veg. oil. I then tempered in my oven for 30 mins at 400 deg. (the oven seems to be calibrated at least reasonably, as the temper color on the blade was a barely perceptible straw).
After sharpening and testing as described above, i figured i may as well try quenching in water...which i did as described above except in 90 deg water. I then repeated the tempering process and testing process...with the same results.
I then attempted to quench in cool water (~65 deg.) and didn't even attempt a temper. I re-sharpened and re-tested with the same results...this time the blade was less sharp...barely hair-shaving. Also, I took care not to put on too acute of an edge bevel. The blade geometry at the edge is similar to (actually a bit beefier) several other knives I have that cut into the 2x4 without any perceptible edge damage.
Please Help!
Dustin
Please Help!
Dustin
