Bill,
I was gonna say that there isn't any way to quench one edge and then the other, but I got called away to dinner, and I was thinking,
If in stead of moving your blade in the bath to cool it, you add a couple of jets, (whirl pool quench) the moving quench bath pulls the heat from the blade. now roll the the heated blade edge point edge through the bath. If the blade is thin enough, it just might work.
years ago when I was an aprentice, I asked how a particular tool was made and was told that I had to heat w-1 to critical and quench it in oil. This causes only the outside of the steel to harden, while the inside stays soft. That way a fine edge could be ground on an impact resistant piece of steel.( this of course does not work with oil hardend steels)
I did it accidentaly to a dagger. I was trying to heat up an 11 inch to critical with a torch (actualy 4 plumbing torches) I got the edges and point to temp, but the spine didn't quite make it. after quenching, boy was I suprised, I don't know if I could do it on purpose though
The guys here have a method that uses clay, but hopefully one of them can explain it. I'll have to play around with it before I realy understand it. I have drawn out the center of a blade with a torch. The color to watch for is dark blue, go slow and quench often to keep the heat under control.
but if you don't want to do alot of engineering, and you don't feel lucky you should get someone to explain how to use clay.
