Hardest Leather Strop
As I continue to try different tools, I am finding that I like very firm leather strops. I have been using a Flexcut strop with ok (and getting better) results. The leather on this strop is very thin and firm, but the usable surface is about 2" x 6". I want something bigger, but just as firm. I am not all that interested in building my own strop right now, and want to stick with leather.
So, what brands would you suggest? Is Flexxx Strop firm? Omega Black Magic? I am a turkey. Baste me with your knowledge.
Thanks!
If you want a very firm leather strop why not getting a Balsa wood strop instead or use paper over coarse stone or on HeavyHanded's washboard?
I like these strops from Sharpeningsupply.com: http://www.sharpeningsupplies.com/8-Leather-Bench-Strop-P263.aspx
I only order the smooth leather, not the flesh side. This leather is quite thin and hard! As almost always, applying a crayon type compound is not easy but I use the leather strops these days almost exclusively with CBN or Diamond spray anyway.
I'd think, if wanting the firmest leather strop, I'd go shopping for a quality barber's strop, as the better ones actually process the leather (cased/compressed/hardened) for the best performance on razor edges. I don't have one, but the top-tier barber's strops in horsehide would be what I'd be looking for, IF wanting a high-performing bare-leather strop (used with NO compound). Otherwise, there are much simpler, more readily-available and much less expensive materials available for use with compound; I'd argue they'd even perform better than many or most cowhide leather strops used the same way. Any use of compound will render moot any characteristics of the leather itself, save for the basic requirement that it easily takes and holds the compound effectively; this is where some other substrates like linen/denim will do even better when affixed over a HARD backing. Leather of any kind really only holds a small advantage when used without compound on already-very-fine edges (like razors); some steels really respond to that, if capable of taking and holding such fine edges. Even then, expensive leather isn't really necessary, but might be beneficial IF the $$ went into the processing of quality leather (such as for first-rate barber's strops). I'm certain I'll never spend big $$ on another leather strop of any kind, EXCEPT in the possible scenario where I might go shopping for a barber's strop someday.
If firmness for strops is the absolute priority anyway, I'd be looking at wood instead of leather; I've liked basswood & maple for that. For both firmness and compound-holding ability, I've yet to see a better combination than linen-over-wood (firmly affixed with adhesive); the hard-backed linen's ability to take and firmly hold a lot of compound makes for extremely aggressive (FAST) burr-removal and polishing, with very, very crisp results at the apex. And hard-backed denim or linen used bare, without any compound, works very well for stripping a lot of fine burrs away.
David
how about making your own?
I took Stitchawl's recommendations and made my own (plenty of threads about it)
I bought a nice big piece of Sheridan Leather and rolled the hell out of it - the result was some very firm strops!
Thanks for all the great posts! I am going to explore some other materials (denim, balsa) and making my own strop.
The most firm, dense leather easily available is sole leather for shoes. NOTHING beats it for these qualities. If you go to your local shoe repair shop and buy a size 13 sole, it will cost just a couple of dollars, not require any processing (it's already been done commercially,) and all you need to do is cut it to size. This leather is taken from the shoulder/back area of the hide of older steers, then while still wet from tanning, compressed under steel rollers. This is why it lasts so long as shoe bottoms. It ain't pretty, but for a piece of leather that is rock hard and smooth, there isn't anything to beat it.
Stitchawl
