This is one question I've personally never seen discussed and am curious about. If you heat treat a blade (standard heat treat, oil quench) how does the inside (center) of the steel harden as much as the outside or layers close to the outside? The steel is hardened from the oil due to the rapid decrease in temperature, right? Then wouldn't the outer layer of the steel cool at a much faster rate than the inside of the steel? And I imagine on thicker blades this effect would be even more pronounced. Just as heating up a big chunk of steel takes longer, wouldn't it take longer to cool down as well? Never seen this addressed before. Wouldn't this be a problem because if you sharpen/reprofile/grind a significant amount of edge away, you would be exposing what I would think would be a much softer core.
I've never heard of this being a problem , I'm really curious about the science of what's going on here. Any insight appreciated. Thanks
