- May 16, 2006
As counterintuitive as it is, I can get my brain around the idea that given two pieces of the same steel with the exact same geometry but at different hardnesses the force required to flex the steel will be the same. But accepting that leads me to question why people are reluctant to put a very acute edge angle on any steel that is softer than say 60 HRC. Here's what I don't understand:
Let's say I have two of the exact same knives in CPM 3V. One is at 62 HRC and the other at 58 HRC and I've thinned the edge of both down to 10 degrees per side. Now let's say I go to forcefully cut some thick plastic or maybe baton through some knotty wood. The thin edge on both should presumably be flexing to the same degree. If the edge on the knife at 58 rolls because the force exerted has exceeded the elastic range of deformation shouldn't the edge on the harder steel snap or chip? Boiling it down, my question is does a harder steel of the exact same type have a greater elastic deformation range than if it is run softer? Seems counterintuitive to me. If it doesn't than why is it so often claimed here that only harder steels (60+ HRC) can be taken down to thin edges?
