- Sep 27, 2004
For a large, heavy bladed knife that will mainly see heavy chopping, I obviously want no chipping whatsoever on the blade and want a tough blade that can take extreme abuse. I have a big blade made from O-1 that I am currently performing extensive tests on and it is walking a fine hardness line at this time. I ran it through two rounds of tempering and afterwards the blade passed the brass rod test so I sharpened up a section and did some chopping tests. The edge does not chip out whatsoever, but in order to attain that toughness, I feel it's edge retention is a bit low. I can cut a 2X4 and still shave, but can see some tiny dulling in the blade under magnification in lighting. Not doing much chopping normally, I am unsure of normal wear and tear caused by full force blows into wood/knots etc. I am at this point trying to gauge if I have made the blade a bit too soft. Can a blade pass brass rod tests and still be too soft? I have no hardness tester.
Blade skated a file post HT and a file will now slightly dig after temper. I am confident in my pre quench temps, as well as my quenchant temp and I am sure i got it below the nose for O-1 as I normall work in 1095 and harden with no problems and a much shorter quench window....Temper was 2 hours at 400, 2 hours at 425. Showed a nice straw color...nothing darker.
Any comments? Should the blade be able to take a 2X4 in half multiple times and show zero dulling whatsoever, or should the dulling simply be minimal enough to allow shaving,
