Hardwood Flooring
I was thinking of posting in the workshop, but this is about the wood itself, rather than installation. We are looking at ripping out the carpet in our bedroom and hallway and replacing with a hardwood floor. I like the wider plank look although the hardwood floors downstairs are the common narrow boards.
What kind of wood do people like for flooing?
Is it a historic home? If so, there's a good chance the wood floors are already present beneath the carpet.
Our old house is a real mish-mash. Most of the home originally had pine floors; in the first floor rooms the pine has been covered by standard narrow oak, while the upstairs is still all pine. One room, a newer 1910-ish addition created by enclosing an outdoor porch, was built with scrap/salvaged materials and has a maple floor.
If doing a new home with wood floors, I'd probably pick a wider plank than the standard historic stuff. And I'd lean towards pine since it gives more flexibility as far as staining and finishing. If an ultra-modern home, I'd consider something like the new bamboo flooring.
Anything but veneer laminate. :barf:
Just a heads-up: If the bedrooms are on a second floor with living space beneath, there may be a lot of extra noise transmitted between the stories of the house. Footsteps above, television and voices from below... Just something to take into consideration - might save a lot of money and aggravation to think about it now rather than later when it's too late.
Our historic home has a set of ceiling joists above the first floor, about six inches of empty space, and then a second set of joists for the above floor. As a result, there's almost no noise transfer at all between the first and second stories. Between the second and third floors, on the other hand, there is only one set of joists so carpet and padding on the third floor was a necessity.
Hope this helps.
Go with real wood and not laminate whatever you do. I have 3/8 inch real teak from Lumber Liquidators that I've been happy with. Bellawood if I remember correctly. The wider plank is the style now.
Definetly go with real wood either a solid or engineered, I engineered try to get something that's 1/2" I thicker will help with noise if on second floor also use a good glue like bostik vapor lock it has moisture and noise protection. So many different makers out there just make sure the wear layer has at least 1/8" thick surface. Other then that its all a matter
Definetly go with real wood either a solid or engineered, If engineered try to get something that's 1/2" Or thicker will help with noise if on second floor also use a good glue like bostik vapor lock it has moisture and noise protection. So many different makers out there just make sure the wear layer has at least 1/8" thick surface. Other then that its all a matter of preference.
We have bamboo, it's beautiful and holding up to three dogs well. The previous laminate sucked and didn't hold up to dogs / kids very well.
I definitely agree with bamboo.! Beautiful stuff. Cork is high on my list too, just very pricy
