About 4 years ago I bought a G-10 Harpy. Abouth 3mm of the broke off and Spyderco reground it for me. I liked the knife but had two problems. First, it was tight and hard to open. So tight the tang was actually scratched on the steel liner side. At the national NRA show in 2001, the owner of TuffGlide put some of their liquid material on my knife. Within 5 minutes the blade was loose enough to be fun (i.e. spyder droppable). It stayed that way for about 1 1/2 years, until I felt it needed replenishment. So try tuff glide for those sticky spydies.
My other problem was the tip was always blunting. I spent a lot of time sharpening only the tip. This is a problem for the Harpy when used as an EDC. Given the hawkbill shape it really needs a sharp tip. I though it was the ATS55 steel. I finally noticed a small gouge on the steel back spacer where the tip was bottoming out on the back spacer. This is suprising since the tip was already shorter than original. In addition, I could see light between the tip and back spacer when the blade was closed. Some how when snapping shut, the tip goes past the resting position and slams into the steel, blunting the tip. I don't have a collection of small files, so I wasn't sure how to fix it. However, the Leatherman has a file, as slim as a knife, with an edge that can easily slip in between the scales. I filed it down and now my tip stays sharp.
Hope this helps with anyone else who has the same problems.
Any other spyderco lockbacks bottom out on closing?
