- May 8, 2014
I have a O1 1/4 x 4 X 18 bar --- going to grind out a parang machete when I get the even heat furnace. Should I use the anti-scale powder?
I would use the liquid rather than the powder. if you get blobs of the powder on your blade, it can cause pitting. With either of them, you need to have a clean, degreased bald. If you have oil, etc, on the blade with the liquid stuff, you will know as it will try to "bead up" on you like rain on a treated windshield.
No. It should be dry before you put it in the oven.Will it have any issues with the fire bricks and such?
I've been pondering coatings myself. I get hung up with quench contamination, tho. The particulate from the coatings comes off when quenched. Occasionally only some of the coating will come off during quench. Sometimes a bit more of the coating comes off. It does settle at the bottom of the tank, and the oil is still "clear". I've heard that if the oil is still "clear", so to speak, it is not a problem. Still, I hesitate to use coatings because of this reason. I think I'm being over cautious here...to a fault maybe.
BrownellsWhat is the name of the liquid anti-scale so I can find some?
Yes.
Yes, you are.
If I am doing thermal cycles in the oven, typically "sub critical anneal" or stress relief cycles, I use foil for those.One note... The ATP products won't stay on through thermal cycling, so if you're planning on doing a series of normalizing/grain refining heats, this is likely not going to work for you. Every time I tried it, the coating flaked off while it was sitting outside of the kiln cooling. Otherwise, it's much easier to use and cleaner than PBC Antiscale - but PBC will hold up to repeated thermal cycles. Can't have it all, I guess!
I would not try it if you are running up against the maximize operating temp of the foil. You might be able to resuse the high temp foil made for stainless if you are doing carbon steel. Hell, I have used the lower temp stuff as an envelope for forge welding a "Ferry flip" damascus billet, but by the time it got up to heat for the second welding pass, it pretty much disintegrated into big flakes when I pressed it.Can SS foil be used during the normalizing of carbon steel and then the same envelope be used for the subsequent two or three thermal cycles? As in, can it be re-used a few times? Seems like I remember it to be used only once, but I think that is in reference to heat treating stainless, at those higher temps. So expensive
