- Jul 29, 2010
If so, what are your thoughts....
http://www.knifemaking.com/product-p/la810.htm
My advice... Dont buy mystery compound of an unknown abrasive type , particle size and concentration.
Sound advise. Can you recommend a brand/type? Thanks
David
What steel(s) are you wanting to finish, and to what finish level (toothy/satin/mirror/etc)?
The vendor description of the pink 'scratchless' compound sort of sounds like it's geared mainly to softer materials (brass, nickel, wood, bone), and maybe 'OK' for some steels (hardness & type is a mystery). Putting two and two together, if the compound is actually 'scratchless' on such soft materials as described, consider how ineffective it would likely be for refining hardened steel (can't hone or sharpen without actually 'scratching' the steel). I usually shy away from compounds described like this, and instead look for those known (with certainty) for working on hardened steel, or at least primarily described for polishing stainless steel.
For most stainless cutlery steels up through something like D2 or ZDP-189, any of the popular AlOx-based polishing compounds work pretty darn well, such as Simichrome, Flitz, Mother's Mag and at least some of the stick-type compounds like Ryobi white, Flexcut Gold. I've lately been tinkering with some Sears #2 (grey AlOx) compound that seems to work almost as well as my favorite (Ryobi white rouge), maybe to just slightly less-polished finish (very slight difference). For steels with high vanadium content, like S30V and beyond, diamond or CBN compounds would likely be best.
David
Mostly 154CM, S30V and A1 Toothy - Satin
Not to change the subject of my on post but when we talk about toothy, is this achieved by less fine finishing such as EEF stones/Plates and less stropping David?
David
