- Feb 4, 1999
Okay...I am testing a knife for a maker that will remain anonymous at this time. The knife has scales that are held on by bolts. The fit wasn't perfect in the rear of the knife and I had to dismantle the knife to see what the prioblem was (bolts too long and weren't snugging up the scales to the tang). I replaced the scales and tightened up the bolts and on one of the four bolts I heard and felt a little grittiness. I've been a bike shop mechanic for over three years and work around threaded parts constantly, most of which are VERY fragile, so I have a good touch when it comes to not overtightening things. I figured it was a little grit in the threads, but boy was I wrong!
Anyway, I was testing the knife in the kitchen today and of course water went into the gap between the tang and the scales, so I had to dismantle it again to dry it, and I figured while I was at it I would go ahead and just grind a bit off each of the bolts to improve the scale's fit. I got it apart, dried it out, but when putting it back together one of the rear bolts didn't want to thread in, so I removed the scale and noticed at that point that some of the metal around the rear hole in the tang had sheared clean off and was still threaded around the bolt! When you look at the hole in the tang, which was not countersunk, there is a round wedge shaped cutout where that metal had previously been. It looked like the hole was now countersunk and it was nearly perfectly round! I figure what happened is that a stress riser formed around that hole and caused the metal, which is D-2, to be brittle, resulting in it shearing away with the light force of the screw's threading motion.
Anyway, what do you think happened?
My Custom Kydex Sheath page:
http://www.geocities.com/CollegePark/Lab/1298/frames.html
Palmer College of Chiropractic
On Two Wheels
agocs_s@dd.palmer.edu
Madpoet (Mel Sorg, Jr.) Tribute page:
http://www.geocities.com/CollegePark/Lab/1298/madpoet/main.html
On Two Wheels
