Hatchet ID? : YOU GUYS ROCK BTW.
LMGTFY
It's completely void of any distinguishing marks. But it's old enough to have convex cheeks even if they're a bit thin. Probably 1960s or early 70s. Most likely American but could be Scandinavian. They exported a lot of moderately priced axes back then. Should be a decent user.
Y
LMGTFY
Thank you!!
That’ll clean up nice.
Parker
I'm hoping so! Random side question for you. I've heard of vinegar as being generally sacrilegious. Are you an advocate of a fine wire brush on a bench grinder with something like this? Or do you think there is a better method? I'm looking at selling some of my heads once I get them touched up and I'm soaking up as many opinions/knowledge as possible. Just wanting to maintain the integrity of my axe heads and maximize their value. :)
The bad thing about wire wheeling is that it’s too easy to remove all the patina and blast down to shiny bare steel (a look I dislike). Bench grinders spin at about 3400 rpm, and most wire wheel bristles are fairly stiff. I mounted a soft wheel on a 1725 rpm motor, which gives better results, but finding those parts took a while.
If you must wire wheel, first practice on some old rusty hinges or scrap to get a feel for how light to go, and keep the workpiece moving.
I don’t sell tools, but it seems tricky to maximize their value by trying to guess what an unknown buyer considers attractive. Best of luck.
Parker
I've used vinegar and a wire wheel, I prefer a wire wheel for looks. My modus operandi was a 4 inch angle grinder with a wire wheel attachment, but you could use a bench grinder or a wire brush attachment for a cordless drill.
It's all about rpms and material. It begs for a table with shading in the cells IDing the levels of what's relatively safe or not to hit, let's say, a Black Raven. Personally the rocks I throw at the black ravens around my house are pretty low rpms, and never one was worse for wear. OK, never hit one, and ok, never threw a rock at one. Ravens are really cool birds.
I also use a brass cup brush chucked up in my drill press. I've had great success with that and prefer it over a chemical soak.
Soft brass wheels would certainly make a difference.
I’m not saying don’t do it, just saying (in agreement with others) go slow, use a light touch, practice on some crap that it doesn’t matter if you ruin before you start in on your sale items.
Parker
Your right, the old soft wrought iron bodied axes will go right down to shiny steel very easily. With the all steel axes it don’t much matter, they turn a dark color from the heat of the brush against them. This axe is a modern all steel axe.
