Hatchet-Knife-TacTool?
I am looking for advice -
I currently use a SAK and an SRK for my back country fun, I am thinking of adding chopper. From what I have seen the only real use of a 9" blade is chopping and it seems like a hatchet/tomahawk would do that better than a knife. The SRK chops pretty well, but lacks the size for bigger limbs. I want to carry as little equipment as possible since I am hunting and already pack a rifle and mini-kit.
I am thinking of switching to a small hatchet and the SAK while dropping the big knife altogether. Or maybe -- after reading Brian's review, dropping the big knife and adding the Becker Tac-Tool. Any advice from those who are more experienced would be very helpful.
JP
Personally, I'd drop the big knife for a small fixed blade and add one of the new Gransfors mini-hatchets.
Mike
plattj1 :
On small wood a really high performance large blade will generally outperform a quality hatchet (Bruks) in raw chopping performance because of the slimmer profile and make a much better limbing tool and for all around for light brush work because of the extra edge length and profile. High performance blade means something with a geometry like that of a forged bowie from a maker like Fitch. Now the hatchet does have advantages, it will bind far less than the blade because of its profile and split wood much better for the same reason, it also doubles as a much better hammer.
Most production bowies and simliar class large blades will NIB chop at about 45-75% of a quality hatchets ability on small wood. You can turn the blades into much better choppers and all around cutters if you are willing to do some work, but without something like a belt sander you are going to need a lot of work to hog the necessary metal off as most production knives have edge bevels that are 2-3 times as obtuse as they need to be for wood work. This is a few hours with a hand stone even with one that cuts very well, 220 grit SiC waterstone for example.
That being said a quality hatchet will remain competetive with even the best of large blades on small wood (2-3") and will start to outclass them readily on wood that is larger than the face of the hatchet, usually about 3"+. By using a multiple hit opening with the hatchet you gain a penetration advantage of 2:1 over the larger blades and can thus open up much larger wood. The difference this makes can be very significant, the extent of which is dependent highly on the skill of the user as well as the type of wood and quality.
A decent starting blade for a chopper is a 12" Barteaux machete. Put a decent edge on it and you have a fine work tool. On the negative it will bind readily and thus on harder woods is not really a functional chopper. A decent bowie from Ontario will cost a little more, but if you get a good one (the QC is poor), and bring the edge down a lot you will have something that can chop alongside a quality hatchet, but won't have the same level of edge strength and edge retention. This is about the price of a quality forged hatchet (Bruks).
Above the Ontario line are blades like the Beckers, Cold Steel etc., and above that are the high end versions of production knives like Busse and Reeves. From there onwards you are into the custom field and if you pick the right maker, you should be able to get a better custom made blade than any production because it will be adjusted to your specific needs. Custom does automatically mean better, just the possibility of such.
Gransfors Bruks makes quality hatchets if you want to go that route and so does Wetterling to a lesser degree. Ref :
http://www.bladeforums.com/forums/showthread.php?s=&threadid=171759
Something else to consider is a quality folding saw :
http://www.bladeforums.com/forums/showthread.php?s=&threadid=173443
As well of course there is the khukuri. It is like a bowie that has been severely axe influenced. Spend some time on the HI forum on this website to get a perspective on their performance. Will Kwan recently described taking down a 20"+ tree with one of his khukuris, no small feat even with a good full sized axe.
More info on chopping with some specific comparisions of a few blades :
http://www.physics.mun.ca/~sstamp/knives/blade_testing.html#chopping
-Cliff
As usual, Cliff's analysis is impeccable. However, he also mentioned to me the Uluchet. www.silverstar.com/turnermfg
It works well for general knife and hatchet chores. If you do any meat cutting/game preparation it is great. If you spend time in wet environments buy the kydex sheath. It is outstanding and very reasonably priced. If you have questions you can call the maker, PJ Turner, at 800-638-9969.
I'm just "getting into" hatchets. I used to use large bowies and a khukuris for chopping, but wanted to try out hatchets after reading so many positive reviews of them.
The biggest difference is in technique. I started chopping with a big, straight edged bowie, then moved onto a curved khuk. Eahc has advatantages, and each has a slightly different technique. Using a hatchet is totally unlike using a large knife for chopping. But once I got the hang of it, I found that I can *really* chop with a good hatchet. Also, you can get a decent hatchet for MUCH less than a decent large chopping knife. You can go to a hardware store and spend $15.00 or so on a so-so hatchet, and easily out chop a knife costing three times as much. And if you take the money a decent knife would cost you, you can buy a GREAT hatchet or tomahawk. So, the better value is definitely going to with the hatchet.
As to a good "combo" that is light weight, yet able to do it all, I would suggest your SAK, a hatchet or 'hawk, and Mora knife of some type. A Mora #1 will only cost you about $6.00, yet will be the perfect compliment to a hatchet. And the SAK (or multi-tool would be even better, if you want to buy one) will fill in all the "tool" apsects that the other two don't cover.
You realy need to ask yourself how much wood cutting you are going to do on one of your hunts. I have the small forest Gransfors Bruks axe which blows away any of my larger knives when limbing out 3 inch plus wood. For its size and weight it is a real performer at chores in the woods, especially when there is a serious amount of wood to be cut. However, I can't think of a time that I have carried it when out with a rifle. Then again we don't "pack out" for days in this country as you can do in the States when out shooting. The axe could build you a substancial hut to live in and the fuel to go with it whereas a knife could only build a survival shelter. The axe can tackle larger projects as they produce less fatigue. When using a large knife for any length of time you wish you had an axe or better still a chainsaw. The forest axe is about as small an axe as you want to go, as anything smaller is so much less powerful. If you are carrying an axe then you only need to carry a small knife. For the short term most fuel can be found on the ground.
Brush clearing, then a machete is the tool for the job. I do have a 14 inch heavy hardwood machete which I do carry when I know I've got to tackle thicket, hawthorn and such. This blade competes with my axe but only wins out if I need to do some digging as when there is snow on the ground. However my forest pack has the axe and a Glock spade and is my normal work pack.
Having said all this, if I'm with a vehicle then it all goes with me! My newest gismo is a ratchet pruner, but thats another story.
V Shrake :
Yes, the money you have to pay for a quality hatchet is much less than a quality knife. The Bruks small axe (Wildlife Hatchet) is about $50, a good forged bowie that will outcut it will be in the area of $500. Even the low end production blades like Cold Steel are 2-3 times the cost of the hatchet. The Bruks axes are of very high quality, individually forged and have the makers mark on them, by a current popular standard that is custom made.
Greenjacket :
This illustrates one of the points I made in a Busse thread recently :
http://www.bladeforums.com/forums/showthread.php?s=&threadid=172491
Choices of blades are critically influenced by enviroment. On the type of wood that grows around here, of the size that Greenjacket noted, a large parang class blade (heavy machete) will readily outperform an axe on limbing. The branches will readily be cut by the blade and you can sweep far more off with the knife than the axe.
However if the wood was much harder then you would want an axe as the heavy machete class blades can break up on the limbs, and even if they don't, they will not have the power to cut through them effectively. A "Brush axe" (like a billhook) is a tool that is midway between an axe and a parang, and is basically an axe with a short heavy blade for limbing up to around 3-4" branches (which means a very decent sized tree).
Along those lines, of course if Greenjact meant 3" branches in the above, then obviously that's axe class work. The shelter building comparison well illustrates the difference between an 3/4 size axe and a large knife. The axe will made short work of tasks that the knife will find really difficult and combined with a small knife for precision work, and a larger blade for brush clearing you are well prepared indeed.
Regarding the Uluchet, it is a also another fine choice. It would fare well against the mini-axe from Bruks I would assume, but would be more portable because of the size and for the same reason be easier to use for cutting chores.
-Cliff
Leave the SRK ( a great blade) for a slimmer , thinner fixed blade (4-4.75", around 1/8 " thick) and get a minihatchet GB. I am selling my 4.5" drop point hunter from the late Frank Vought, to get a GB. I carry a Grohmann #3 boat knife now, too, and a SAK. Also, don't unter estimate the advantages of a small saw
Ravenn in Ky
I may be a little biased, but have you looked at the tomahawks from ATC? the next generation is a great chopper for general use, and the spike can be used for dragging, as an ice axe, prying, or hooking. The handle WILL NOT loosen. I've thrown mine quite a bit, as well as used it for chopping fire wood and clearing branches. Of course I carry it in a shoulder rig of my own construction, but what do you do?
Also, don't unter estimate the advantages of a small saw.
Except that I've got to try it with a big blade because that's what we do around here, the small saw (like Gerber folding saw or one of many others) has always been the way I go light when backpacking. Problem with both the "big blade" and the hatchet is weight. Carrying a small folding saw allows me to go very light with only a SAK and maybe a nice hunting knife with a 4" blade.
I've got a folding saw I carry in my mussete bag, and it is quite handy. However, if you need to split wood, that saw or 4 inch hunting knife won't do it. If you carry a saw instead of a hatchet, you should also carry a heavy duty 6-7 inch knife so that you can split wood with a baton, if needed. If it's raining, or all you can find is large diameter wood, it's be hard to get a fire going without splitting at least a little of the big stuff.
Cliff, is right 3" stuff as found on a fallen tree. I do use a billhook but I do enjoy using my beafed up machete more as it has more reach. But then it doesn't take long before I find a branch that needs the axe.
Matthew Rapaport is completely right, we all rather overlooked the very useful folding wood saw solution. When I used to try to save weight and carried my CR Project, it was a Gerber folding saw that backed it up (SAK wood saw sometimes even).
A good saw will produce clean cut quantaties of survival stakes/poles, of the 2" variety. Just the job for all sorts of tasks. Anything thicker is a bit of a slog, but you can cut branches thicker than the length of the blade, if you have the patience. Certainly its one way to go if you want to go light. However, I've yet found a folding wood saw that is both robust and efficient. Made for the gardening maket they seen to blunt too fast. Efficient means nice and thin with good agressive teeth. Getting hold of replacement blades is a pain.
A light weight small bow saw shouldn't be overlooked either, but they are bulky and job specific. They also clang about, so not the best solution for when out hunting.
(Cliff, have I missed that saw review, or is it still in the pipeline?)
A few of you have mentioned billhooks/brush axes. However I have never found a good source for them. Where can one get a good billhook (in the US)?
I have gone more ultralight when camping (I'm too old to carry a bunch of steel around). So now I carry a multitool with a saw and a 4" Helle knife. It won't do everything but it will do enough.
Robert :
I have used the Rogers Rangers Spike and the bit and edge are too thick for wood work, it will be readily outperformed by a quality hatchet for any cutting and chopping. However if you threw the hatchet and missed you could likely blow a large piece out of the edge, such an impact on the tomahawk would not cause a major problem as it is designed to be able to handle it.
Recently ATC has produced another tomahawk with an O1 head which sports a much more acute edge. I would assume that it will cut and chop much better than the Rogers Rangers version. As well, like you noted the head/handle attachment is much stronger. The steel is also much harder which will allow a much crisper edge, longer edge life and less impaction off of hard contacts.
V Shrake :
The saw will be able to cut the wood down the middle, or simply saw sections off which the smaller knife can point split readily. As you note however a large knife or small axe will do the same task with far less time and effort.
Greenjacket :
Robust is next to impossible. All the small saws I have used are pull cut which means that you can break them quite easily if you push too hard, I have bent a few and broke the tips off of others by experimenting, seeing what would happen if I tried to run them very fast as if I was in a critical situation. Getting good edge retention should not be a problem however, as most some with impulse hardened teeth.
The Felco one I have used as of late is more durable than the others I have used, but still would buckle very easily if I leaned into it on the push, this of course is grossly abusing the saw as it is not meant to be run that way. The review :
It comes with a chrome plating on the blade which I thought was hype until it found it outside in the woods one day after it dropped out of my pocket the day before. It had rained extensively that night and there was not one spot of rust on the blade.
I have a collapsable buck saw with a swede saw blade that will easily fell medium class wood (5-7). It clearly wood many times faster than the Felco pruning saw. Yes it can rattle about in the tube once it is packed away, but all you have to do to prevent this is just wrap the components. Takes a few minutes, but you can eliminate any noise problems.
The one I have is called the Trailblazer and comes in two lengths, I think 18" and 24". I got the larger one. You can also buy replacement blades and blades for different tasks (bone, meat saws). I will be putting up a post on it shortly.
-Cliff
Cliff,
With all due respect, I gotta disagree with you on the Rogers Rangers hawks and woodwork. I haven't compared it to an ex or hatchet, and your statement, I'm guessing, was an implied comparison.
Robert H, we used the RR hawks very extensively to split wet logs and build shelters on a recent two-week backcountry expedition in Idaho. We got hit (in June!) by wet, hypothermic, snowy/slushy conditions, and the hawks saved us from a lot of misery because of their chopping abilities, and ability to use the spike as a wedge to drive the splits into the wood faster.
Cliff, I got the chance to see the Next Generation Hawk -- you gotta check it out. The angles are much more acute (thinner). The fit and finish, and edge grind were literally PERFECT as far as I could tell. The head is much smaller than the RR version, but it does look like it will bite deeper for chopping and utility. The spike was symmetrical on all sides and needle sharp in the point. Very well done. I'd be curious, if you get one, to hear what you think.
All the Best,
Brian.
Brian :
Well yes, all performance is relative, you can only judge something in relation to the performance of something else. As for being suitable, you can use anything to do anything if you want, the Cold Steel shovel for example can be used to chop and cut, however it does it about as well as I run the 100 (which is a bit faster than the tide changes but not very much). Therefore I would not rate it as a suitable chopping or cutting tool as its performance is horrible as compared to something which is actually designed to do that. But of course it does it a lot better than a regular shovel, so it is critical to note what baseline is being used.
To clarify the comment I made in the above if you compare the ability of the Rogers Rangers Spike tomahawk to a quality small axe like the Bruks Wildlife hatchet the tomahawk will be readily outperformed chopping and even more so cutting. The hatchet will also be more comfortable in hand, transfer less shock (handle issues) and has a much more secure head/handle attachment as well a much harder steel (usually of better quality in general but not in this case). In regards to interpreting the performance, what level you will tolerate determines what is "suitable" and thus depends on the individual, this is why I clarifed exactly what level I was referring to in the links given in the above.
To get a little more specific along those lines, I found that the tomahawk chopped at about 69 +/- 5% of the ability of the Bruks hatchet. This was the median performance of a 30 cut run. I will be repeating this shortly as there are some details I am interested in, but the ratio should be stable. Now this looks to be decent performancce, but when you consider that the tomahawk is 30% heavier with a longer handle it doesn't look so good. If you adjust for the mass, you get a performance ratio of 52 +/- 4, adjusting for the length will bring it down a little more into the forties. Note as well that this is a one cut rank, if you did the chopping without resting constantly fatigue will set in much faster with the tomahawk, both because of its lower performance, higher mass and various handle aspects.
In regards to cutting, I found the hardwood whittling ability of the tomahawk to be about 25 +/- 5 % of the hatchet. Again as with the chopping this was a one cut run and there was no fatigue influence. In reality unless you are stopping every few cuts, the actual field performance will be even lower as fatigue will set in far more readily with the lower performing blade. There is more details on the two comparisons in the above links.
Besides those two controlled comparisions I also used both cleaning up a lot of ground of small wood to prepare for next year's felling. As well both were used to limb out a lot of such wood lying around. This was mainly 2-3" class wood, very small. This is done to give room to use a chainsaw on the larger wood as well make limbing out that wood easier as you are not having to move around a lot of scrap wood. In addition a lot of scrap carving was done as I like to have a large pile of shavings readily to start the fire quickly in the morning. The axes were also used for various other tasks to get a feel for the general cutting ability. They were also loaned out to friends who do a lot of similar work, their perspective was the same as mine in regards to relative wood working ability. Some complained about the weight of the tomahawk, as it is very heavy for that length, but that just reflects personal ability, nothing more. All enjoyed throwing the tomahawk.
What causes the difference in performance in regards to cutting and chopping? Mainly it is the difference in edge geometry, the edge on the tomahawk is much more obtuse, which it has to be for throwing and such, however any increase in corss section produces a direct loss in cutting ability. In addition the length of the head also reduces cutting ability as it produces a significant leverage disadvantage and it is very uncomfortable to use in that manner. As well the straight handle is also not as efficient as the handle on the hatchet which is very specifically designed for maximum power and comfort. More comments on that issue in detail :
I also don't think the head is center balanced on the tomahawk which will effect fatigue and precision. However I don't recall actually testing that but have the impression for some reason. Mine will be skewed however because I have ground a lot of metal off the spike. However I'll look at it this evening.
There are also other issues with the steel. It is a little too soft for the necessary impaction resistance (assuming the edge profile was altered of course in its current state its fine because of the thick cross section), and it doesn't have near the edge retention of the Bruks line. The latter isn't surprising as the steel is much harder, about ~57 RC, just at the limit where it can be cut with a sharp quality file.
In regards to splitting though, yes, I would agree that the tomahawk will split wood as readily as the hatchet, however I never saw the spike as being usedful in that regard. It works well on dry wood, but for felled wood it just bound and would not produce a significant length fracture. The primary edge worked nicely however.
The tomahawk of course has lots of advantages, both the edge and the head as a whole are a lot more resistant to being damaged by impact shock, by this I mean work which is far above chopping, contacts off of hardned wire, rock and such. The edge is also more robust in regards to twisting ans such, I would not use the Bruks axe on heavy bone for example, the spike hawk handles that without any problem besides just getting blunted. The heavier impacts like off of wire and rock can easily ruin a quality axe, however they will just do minor edge damage to the spike Tomahawk. And of course you can throw the tomahawk, and the handle is easily field replaceable.
After I get some more chopping done with the spike tomahawk in its NIB configuration (another day or so should do it), I will be taking the edge down to a suitable angle (12-14) degrees and seeing how the edge holds up. The cutting performance should easily more than double, probably approach triple, and the chopping performance will make a significant but not nearly as dramatic increase, around a 50% gain I would estimate.
It looks like a direct improvement. Andy said he would be sending one out. Once I get it, I'll post up some impressions after working with it a few weeks. The handle looks to eliminate some problems I have had with axe handles which is security in less than ideal conditions.
-Cliff
Cliff:
What would you do to a Production piece like the Cold Steel Trail Master bowie to improve it as an outdoor, woodsy blade? I have an idea what you're going to say, but I'd rather hear it from you :)
Brian Jones' trip made me rethink what I'd buy in a hawk. I thought a hammer poll would be more useful. Thats waht rocks are for, is Brian's answer! And the list of uses for the spike seems endless. The Next Gen hawk looks to be a future classic. I really want one!
The biggest problem with the Trailmaster is the edge profile. This is not a
complaint about Cold Steel specifically, in fact they are better than many
in that regard, however the edge on the knives are still a lot thicker than
they need to be for wood working. On the Trailmaster you can expect an edge
profile of about 22 +/- 2 degrees or so. I would cut that profile in half,
to get more specific I would put a convex edge on it that would sweep out
from about 8-10 degrees and edge at about 10-12 degrees. You will see an
increase in general cutting ability by about 100% and a significant increase
in chopping, however not nearly as great, 25-50% (depends on your style, and
type of wood).
To clarify, this is no longer an edge that you would use to chop heavy bone,
nor hardened metal, but based on what I have seen it could not do that in
the first place anyway. However if you do want to do heavier work than just
plan wood chopping you can leave a short section of the edge with the NIB
thickness. As well the exact angles that you choose depend both on the type
of wood you will be cutting as well as your technique and strength. Some
experimentation is in order to find what is optimal. The steel will also
influence the geometry as well, better materials will allow a thinner
profile and thus produce a better cutting blade.
Anyway, the edge width is now much greater than when it was NIB. This means
that when you sharpen the blade you have to hone across a greater section of
steel and thus the hone will load up much more quickly and you will see an
increase in the time it takes to finish the edge to a specific level of
polish and alignment. There are two basic ways to deal with this problem,
first of which is to take the knife to a belt grinder and grind along the
primary flat bevel. This will take quite some time as you have to hog off a
lot of metal and it isn't that ideal as it wastes a lot. The optimal way is
to change the primary grind from one of a full flat to two opposing convex
bevels. The first convex bevel should sweep down from about 2/3 blade height
and meet the edge. The second should sweep up from the first and thin out
the spine. This also increases the flex that the blade will take and as well
raises its ability to handle lateral shock
Now while the first change (edge profile), can be done with a coarse hone if
necessary, the second would take many days without power equipment. As well
if you do the second modification you will be removing enough metal to
change the balance of the knife. The balance will be shifted back a little
towards the guard. However the change will not be that great and you can
counteract it by removing the clunky guard and tapering the tang if the
blade loses too much heft. As well, if you are willing to do that much work
you are probably better off making a blade from scratch anyway, or at the
least taking the temper out of it and getting someone to redo the heat
treatment on it. It will make the grinding go a lot faster.
Now comes the handle. There are a lot of personal issues at play here
because so much depends on the size of the individuals hand as well as the
nature of their grip (balance of power, skin durability etc.). First off you
have the materials issue. Kraton stands out as a poor choice for a
wilderness blade is it gets ripped very easily, even the ends of seasoned
limbs will readily tear Kraton not to mention that it will wear down slick
with use anyway. Far from ideal.
In regards to handle shape, you will find a lot of debate here. However
there are general rules to go by. First off all the human hand when curled
in a grip does not enclose a volume that is square nor cylindrical. The grip
should be swelled along the sides and along the top and bottom to fill out
the grip. This does two things, first off all it makes a greater power
tranansfer possible, and second it makes absorbing impacts much easier.
Lastly the end of the handle should have a hook that you can drive off of,
but which is sloped backwards enough that your hand will ramp off on it.
There is a balance there that must be met, if the angle is too steep it will
be uncomfortable, if it is too shallow the grip will be too insecure. Here
is a knife that has an excellent grip (the blade profile is near ideal as
well, its from Ray Kirk) :
http://www.tah-usa.net/raker/img9.jpg
Finally in regards to tips. There is a tradeoff that is critical. The more
acute you make the tips the weaker they are, the more obtuse you make them
the stronger. However penetration is negatively correlated to strength so as
you increase one aspect you directly decrease the other. The Trailmaster has
quite an acute tip that gives very good penetration, however I had no
trouble snapping a large part of the tip off. It does not have the tip
strength I would want in a large knife, nor would I want any sharpened
swedges nor false edges. These will all greatly help penetration, and make a
lot of things effortless, but also prevent a lot of use as well. There is no
rigth nor wrong way to proceed here, just a decision that must be made about
what you want a blade to do.
Can you do anything about the tip on the Trailmaster? Well you could just
throw away some length and grind a more obtuse tip, but you will be losing a
lot of reach, mass and reducing the blade balance if you do so. You would
probably be better off in just going with the tip that is there and taking
advatantage of the greater penetration and avoiding tasks that put a lot of
lateral stress on the tip.
There are other things I would change about the Trailmaster as well, but it
is not practical or even possible (for some) for the ELU to do so. The
handle should not be inline with the blade but dropped which will increase
cutting and chopping ability (for two different reason). The steel as well
doesn't have the required properties that you would want in a heavy use
field knife. It fractures too readily and as well rusts really easily,
something that I would put up with if the durability was there (L6). They
probably just have it 1-2 points harder than optimal. I would also increase
the length a little to give greater protection from harsh vegetation and as
well the extra reach will make a lot of tasks like limbing easier
Basically there are a lot of things I would change about it to improve its
performance, however the only one that is really that practial would be the
edge profile. Other options to explore besides what is given above is an
edge cant (which simulates a dropped handle) and a distal taper.
In regards to spike vs poll, by all means try it out, both have advantages
and draw backs. The more experience you get with various equipment the
better prepared you will be. The Next Generation looks like a very solid
piece of equipment indeed which should be very enjoyable to work with.
I checked the balance on my Rogers Rangers Spike, it is tilted off center
head balanced by about 4 +/- 1 degrees. It does slant towards the spike, so
odds are I have influenced it by sharpening the spike.
-Cliff
