Hatchet sharpening
I got around to cleaning up from a scout camp this weekend and got around to my Gerber PackAxe hatchet. Apparently, a boy or two decided to spit kindling on some rocks and I have some good nicks in the edge. I followed the profile of the grind with a diamond hone and it's sharp again now, still some nicks. I took an eraser to a spot of rust and touched up with Tuf Cloth.
Any useful reason to sharpen out the dings?
I can think of some sharpening I need to do on some dingy scouts!
Phil
The only reason to remove the dings on a hatchet IMO would be if you wished to slice with the edge. I don't see how small dings would impact chopping. I use a metal flat file to remove ding/notches on my machete.
-- Dizos
A few dings probably won't make much difference, but enough of them could hamper the hatchet's penetration while chopping. Also, notches could get worse if you continue to pound on them or if you hit knots in wood. I heard that Gerber axeheads are relatively soft so they might ding more than other brands. If the edge is getting damaged often then you should consider reprofiling it to a more obtuse angle for better durability.
I can't add much to SteelDriver's post, the comment about the dings expanding is a critical one. I would keep an eye on them and if they start to get worse, or you see any problems with glances then sharpen them out right away. Otherwise just let the edge come back to 100% with regular sharpenings.
-Cliff
When a hatchet or axe contacts the material to be chopped, there is a substantial amount of stress applied to the metal of the blade. When the blade is undamaged, this stress is applied very evenly.
The crystals in the metal were in good shape before the offending whack, but afterward their boundaries and internal structures get all screwed up. Basically, the area around the ding becomes somewhat brittle. The metal there is now weaker than it once was, and is prone to cracking.
The deformed shape concentrates stress at the deformity, perhaps 5x what it was before. Thus, a higher stress is applied to weaker metal. Cracks can propagate through the blade.
Most fire departments keep their axe blades unpainted so that cracks may be seen. The way I learned to sharpen a fire dept. axe was with a file. First, file out any deformities. Then put a cutting edge on the axe. Last, blunt the edge just a little by deliberately filing the fine edge flat. This makes the edge more resistant to damage. (Your hatchet may be too hard for a file.)
But then, these kids are not exactly chopping through a roof or prying doors open with the strength of a full grown man. Nor is a hatchet as heavy as a fire axe.
I'd suggest the above procedure as an acedemic excersise, to teach the kids how to care for their tools. It is overkill, but they may decide they want to be more like firemen than "axe-murderers."
Scott
I think the more important thing here is to teach some Scouts the proper use of edged tools! When I was in Scouts, we had a card called the Tote N Chip. First we had to earn it by demonstrating proper use and care of knives and hatchets. Then, if we ever used them improperly, we'd get a corner of the card cut off. If it was more serious or dangerous, more corners would be cut, or the card taken away all together. Once all the corners were gone, you weren't allowed to used any edged tools for a set amount of time, and you had to write an essay on knife safety. Don't know if they still use these, but it's a cool way to teach.
Hey, I have an idea for your next scout meeting. How about a class in hatchet and axe sharpening? I bet a few minutes of instruction followd by some hands-on experience for each scout would be a good object lesson. Hint: find some really dull axes and make them work a little.
Heh, too bad you live in Utah. I've got a few axes that are extremely dull. They're double bit axes of varying length used in lumberjacking contests. I bought a bit of an axe loadout from someone who was retiring from competition, and knew I liked anything with an edge.
TC
