- Jun 30, 2003
I had a couple of (invasive) Buckthorn trees to cut down on my property this past Saturday. I thought: "Self, this is an excellent chance to put that Cold Steel SRK into service. It has a 6" blade and not too hard of a steel; should be a good chopper."
I cut down the trees with the reciprocating saw. I also had this nice little Fiskars multi-machete thing and my Fiskars hatchet:
I thought the SRK would perform about like the hatchet; not even close. The hatchet was SO much better for anything chopping-related. For smaller stuff, I could just choke up on the (hollow) handle and the weight of the head did the work. For branches up to about 3/4" thick, I could often get through with one angled, one-handed swing. I used it to cut off the top of a tree of probably 4" diameter and it was better than a saw because as I got closer to the breaking point, I could hear it start to crack and get out of the way.
The multi-machete tool has a long serrated section on the back; that was useless here, but I guess it could be OK for typical machete-type stuff? (soft plants) The main feature is that the hooked inner section catches the branches while swinging. It was nice for cutting off all the little 1/4" and smaller branches along a longer branch, but not nearly as good as the hatchet for anything bigger.
The SRK was OK for cutting off those little 1/4" branches from the big ones, but that's about it. I used it about 5 minutes and put it away.
I may get myself one small fixed blade knife for cleaning small game, but it'll have probably a 3-4" blade of good steel. Not for chopping.
For the life of me, I just can't see the point of a big fixed blade. Something like a bowie knife would be better at chopping, but probably not as good as a hatchet, so what's the point? The end of it would be dull from chopping. The inside of the edge would stay sharper, but that is of limited usefulness with the tip is dull.
What am I missing, guys & gals? What's the point of a big fixed blade?
I think my next purchase is going to be a high quality larger hatchet; not a full-on axe, but a hatchet that can reasonably be used either two- or one-handed.
