Huh… i should think about that. So far my glue-ups are not pre shaped … just rough scales … so i use that belt to sand down to flat around the circumference of the scales. I *do* however use q-tips to wipe away as much of the squeezed out epoxy as i can. Still, i agree, it does take some work to get through hardened epoxy.There’s a fine line between it curing too hard and having to grind a lot of hardened epoxy off (think $belts$), and catching it just right and cutting about 96-98%off and saving a belt or two. If you cut it too soon it’s like rubber and it is elastic like rubber and pulls some out from between the surfaces. Outside feels dry enough, not so much on the interior.
All surfaces were flattened prior to glue up, just a case of too much pull and too dull of a cut.
I stopped using CA for anything about 2 years ago.
Cush, I rushed this one at 3.5 hrs (6 hours is a good sweet spot for me). I had to go out for an appointment and knew I wouldn’t get back to it until it was too hard.
