- Jan 2, 2014
This project began as a personal challenge and an exploration of the beauty and symmetry that can be found in the sankaku style yari. The cross section of the blade is triangular in this style, the spine quite thick and strong, and the tip is centered on both axis. The basic form is fairly defined, but there are several historical variations on the lengths of the blade and tang as well as the style of sculpting the neck area.
"Appreciation for detail in everyday utilitarian objects is one of the elements that shows up in traditional Japanese craft. Historically, this was expressed by attention to the precise development of form, line, and detail, and is found even in components or areas that were hidden from view or secondary in importance."
Historically, this type of lance would have been mounted on a sturdy hardwood pole about two metres in length, though there were examples up to six metres for defense against cavalry. The top of the pole would have a lacquer finish, several iron bands, and a strip down each side, and like a tanto, the yari would have a copper habaki and a bamboo peg through the tang to hold it in place.
(click the centre photo to see the hada in more detail...)
Blade construction is muku with a sankaku profile and a raised/centered tip.
The blade is approximately 7.5″ long, the tang is 10.25″ long, and the overall length is about 17.75″.
Specifications
長さ/刃長 Nagasa: 6 sun 2 bu 7 rin (190mm)
元幅 Motohaba: 9 bu 3 rin (28mm)
重ね/元重 Motokasane: 2 bu 8 rin (8.5mm)
反り Sori: straight
中心/茎 Nakago: 8 sun 5 bu (258mm)
形 Katachi: sankaku
刃文 Hamon: suguha
帽子/鋩子 Boshi: ko-maru
中心/茎 Nakago: kaku, no mekugi-ana, signed midway
銘 Mei: hot stamped katabami-ken kamon
read more: islandblacksmith.ca/2015/07/hatsu-sankaku-yari/
Specifications
反り Sori: straight
形 Katachi: sankaku
刃文 Hamon: suguha
