Regarding the supposed difficulties in clamping FFG (full flat grind) blades in the Aligner, here's how I've been going about it. Never had any troubles, and in fact, I prefer clamping to FFG blades, because there's a lot more flat & flush surface area to hold onto.
Here's how I do it:
Place the blade in the clamp, with the blade spine all the way back to the stops in the clamp. This is most easily done with the clamp's forward end UP, and the back of the clamp resting on the table/bench.
Pinch the forward-most end of the clamp to the blade, making sure the clamp's inside faces are fully flush to the blade's sides. If the forward adjustment screw is too snug to allow the clamp to close fully flush to the blade, loosen the forward adjustment screw until there's enough freedom of movement in the clamp to allow it to fit fully flush.
While pinching the clamp fully flush to the blade, very gently turn the forward adjustment screw until it JUST BARELY encounters resistance to tightening, indicating the clamp is set to match the width of the blade's spine. It's VERY IMPORTANT to make sure the clamp is still held fully flush to the blade's sides, while doing this. It's relatively easy to over-tighten the forward adjustment screw just enough to pull the clamping faces away from flush.
Now tighten down the rear adjustment screw, as tight as you can make it. Check for blade slippage or other movement in the clamp. Also check to make sure the blade isn't rocking back & forth, which would indicate that the blade is not fully flush to the inside faces of the clamp.
The boldened text above is my not-so-subtle way of emphasizing how important it is, to make absolutely sure the clamp is fully flush to the blade. That makes all the difference in the world, in minimizing slippage or other movement of the blade in the clamp. This also applies to any of the other clamped systems, such as Lansky and Gatco.
Other tips:
For blades that are a bit more 'slippery' in the clamp, some masking tape or painter's tape, on the blade, can sometimes help with that. If it's still moving a bit, I've had very good results using a piece of med/fine grit wet/dry sandpaper (maybe 400+ grit), with the abrasive side to the clamp (paper backing to the blade). For me, this has actually worked better than tape, in preventing slippage of the blade in the clamp. Obviously, putting the paper backing to the blade is preferable, to prevent scratching the blade.
