- Feb 1, 2007
Has anyone else noticed that on some knives after you have ground it a few times that it becomes smoother and sharper than it came from the factory?
Are you talking about reprofiling or touchups? I can get knives sharper than the factory sharpness so I always give it a quick touchup when I get them.Has anyone else noticed that on some knives after you have ground it a few times that it becomes smoother and sharper than it came from the factory?
When the edge is put on at the factory wit a grinder it is easy to "work harden" the edge. After a few times sharpening the knife you remove this "hardened" portion making it much easier to hold a fine edge.
Oh, yeah ... others have noticed this as well, and when you consider the way edges are applied at the factory, the chance for their to be damage to the steel from overheating -- sometimes resulting in annealing/softening of the metal, sometimes discoloration -- is pretty high. It's often recommended that you give a new blade a really good sharpening or two if there are any edge retention problems. Often this solves the problem.I guess I didn't elaborate enough. What I meant is that repeated sharpenings seem to improve edge quality as if the steel at the edge is stressed or maybe overheated from the sharpening at the factory. This is merely conjecture on my part trying to find an answer. I haven't noticed this on all knives just every now and then. The first time that I can remember is with a Gerber EZ Out in ATS-34. The edge didn't seem to smooth out until after a few rough grindings and I got back in the blade farther.
