- Apr 3, 2011
So I got an old, well used surface grinder from a guy on craigslist probably 8 months ago... finally got up and around to messing with and using it but am having some sort of issue where it's leaving dimples all over the surface of whatever I am grinding. This is what I have done so far:
One weird thing I've noticed is that even if I don't lower the wheel at all after I have made a pass, I can continue to make passes in the same spot on the metal and throw sparks every pass (I only counted up to 15 back and forth passes and it was still doing it slightly).
Any ideas guys? I'm at a loss...
- Made sure the magnetic chuck is level and that the grinder is very stable
- Checked all of the moving parts (chuck, spindle arm, wheel, arbor, etc.) to make sure there was no play and nothing was loose - all was good
- I've tried 3 different wheels, and dressed .100" off of the last one in .010" passes. When I dressed the wheel I locked in the x axis as much as I could by those sliding stops in the picture below (I was only able to lock one in and then held the x axis in place against the stop w/ my leg while making the y axis passes to dress the wheel...
- When I grind I am using a Kool mist unit which is spraying right where the wheel meets the metal
- When grinding the metal I am only removing .002" per pass and going quickly and smoothly, not stopping part way through
