- Dec 7, 2009
This past Sunday I had a hankering to buy a knife. The problem was that money is a bit tight this month, so I was out of luck. Then, it hit me. Make my own. Okay, I'm not a knife maker and do not have the equipment to make my own blades, but over the years I have acquired a number of knife kits and have even worked a one. They range from Woodcraft mystery steel to AUS6 to 440C all the way up to Spyderco Mule S30V. To date I had only worked one 440C folder from Premium Knife Supply. I am an artist/artisan who works extensively with acrylic, cellulose acetate, wood, soft metals, bamboo and ivory, so much of the skillset overlaps some of those of knife making. I decided to finish off a Woodcraft skinner kit with cellulose acetate scales. Below is a photo of the results about 85% completed with final buffing to the handles and finishing the blade to yet be completed.
I heavily modified how Woodcraft had suggested doing the scales opening up around the front jimping and actually enclosing the rear upper jimping between the scales enclosing the whole handle rather than just part of it as was intended by the maker. I then took the scales down just a bit at the rear jimping so that the jimping extends above the scales just a hair but is functional but still enclosed between the scales. The original kit called for the scales to be pre-finished and screwed on but I went with aluminum pins grinding most of the scale (except for the leading edge at the blade which was finished before attaching) to the blank.
I know that it isn't the best steel (Woodcraft couldn't tell me what it is), but once the blade is finished I think I'll have a nice little skinner for limited use. If you have ever considered trying a knife kit I would highly recommend it. I'd love to be able to make my own blades, but with a kid in college the machinery (despite having a pretty full shop) just isn't in the budget. I think once I'm working the Spyderco Mule blanks and more 440C and VG-10 blanks I'll really have something.
Give it a try!
Here's the upper rear jimping enclosed between the scales. Enough jimping is exposed to be functional yet pretty much invisible when viewed from the side.
Give it a try!
