- Sep 24, 2003
Have I been silly? Ive been assuming that if I can fairly easily remove metal from a knife edge with my miniature Nicholson flat file (from set #42030) that the steel is too soft.
However, last night I used this method to check the hardness of an old Chicago Cutlery cleaver that holds its edge very well, and I found that the file cut it fairly easily too!
Using a file to check hardness has been often mentioned in this forum, but now Im wondering if Im doing it wrong. Maybe the miniature Nicholson file Im using is super hard and has extra sharp teeth. Ive used this file quite a lot on mild steel and it still cuts it like butter. What is the typical hardness of a decent file?
Ive about convinced myself that I am doing this hardness check wrong. What is the proper way to do this, and what kind of file should I be using?
Thanks in advance for your generous help!!!!
Geoffrey
Geoffrey
