Long story short, I came across a Tasman Salt on eBay and I've been obsessed with that beautiful blade shape ever since.
I then made the mistake of researching its utility and it seems like there is a consensus that with the exception of food prep it functions pretty well as an EDC blade and in particular does bad things to cardboard boxes.
My most arduous cutting task is removing the folded flaps of the boxes so we can organize them on shelves using the box itself as a container and have easy access to the precious cargo inside. I often don't have time to pull the box down and de-flap, and the items inside can be damaged by my blade, so control is key.
For the cuts needed, it seems like a hawkbill blade will work pretty well, especially considering I'd be doing some cuts that the blade was designed for.
Nonetheless, I feel compelled to get a second opinion from you intense hawkbill fans before I drop the scrilla on one for myself
I figure, why start with a Crossbill when I can just get Harpy or Tasman Salt?
Any other smallish Hawkbills I should consider?
For the specific task of cutting off the flaps of boxes, will a SE or PE benefit me the most?
Thanks much in advance!
-Chris
-Chris
