HDS Ultimate 42 (flashlight) review
BACKGROUND INFO:
I've had my HDS for a few days now so I just thought I'd post a review for anyone interested. I wanted the extra functions of the Ultimate but I couldn't justify the price of $180 for a flashlight that I really don't need; so I got the Ultimate 42 instead of 60 :rolleyes:.
Currently, the HDS line comes with a max of either 42 or 60 lumens. The Basic line has 4 settings that you cannot change. Also, it will always come on in the primary setting of 10 lumens. The Ultimate line lets you change the 4 settings to any one of 20 different brightness levels. You can also make it turn on in any of these settings and it includes features like SOS, blink, locator beacon, etc.
Basic:
http://www.hdssystems.com/EdcBasic.html
Ultimate:
http://www.hdssystems.com/EdcUltimate.html
I bought mine from Battery Station. Great service from Kevin and I got free batteries too!
http://www.batterystation.com/hds-edcflashlights.htm
REVIEW:
Wow, this is a cool light!! :D
Fit and Finish:
Good anodizing. There is no battery rattle and the clicky tailcap button is the perfect tension. There are no sharp corners and the checkered body is not too rough so it shouldn't wear a hole in your pockets. There does seem to be a tiny bit of dust particles in the reflector, not a problem though.
Size and weight:
A little over 3" long. Fits well carried in pocket but even better clipped. The HDS is a little bit heavier than I expected but is still pretty light. For me, the weight is not an issue for EDC.
Beam:
Very nice beam for a smooth reflector. Intense hotspot (smaller than beam of Inova T1) with a dimmer corona. The HDS outthrows the T1 by a little bit but has a lot more sidespill. Tint is good, more white than what I thought was the white beam of the T1 :rolleyes: (You know you're addicted when you can distinguish between white and white ;) )
Ease of use:
It took a little while to learn how to use the functions but learning to switch between brightness levels was very easy. On the highest setting, it can light up a room pretty well. On the lowest, you can read at night without ruining your night vision. One problem I encountered is that if you go through the brightness levels or functions too quickly, the light thinks that it is all one sequence and blinks angrily at you. Between settings, you have to wait a little bit (like half a second) to make sure your last input is seperate from your next input.
Usefulness:
I got this light because it is a nice all around light. Instead of buying a Surefire L1, Inova 24/7, and a Peak LED for a gent's light, I got the HDS because it can serve all of those roles. It may not have the awesome throw of the high power surefires, but it will do everything else in a small package. The extra functions may come in handy during camping or hiking trips.
Miscellaneous:
Seems to be water resistant as it claims. One thing that could be improved is the pocket clip. There is a pretty big gap between the clip and light, however, it is still secure clipped to the pocket.
I highly recommend this light to anyone who wants a bright light in an EDC package with lots of functions.
Beam shots, please!!!!
Oops, sorry, wrong forum. ;)
Great review.
I see you received the light a few days ago. Just out of curiosity, how many years ago did you place your order?
Thanks guys.
Sorry, I don't have a digital camera for beam shots, and this isn't CPF ;)
I think if you order through batterystation, you wait a lot less than if you order form HDS directly. I waited for a little under a month including shipping time to Canada.
Is the clip attached with screws? You should be able to unscrew it and gently bend it so that it fits tighter.
Peter, when ya gonna start makin' flashlights? :cool: :D
Nice review! - My HDS Basic 42 should drop in my mailbox tomorrow if all goes to plan! Can't wait to finally get it!
Ted
Well done review!
Thanks for posting it.
When all is said and done do you wish you went for the 60 instead of the 42?
Tom
Great review! I've been drooling over those for a while now. I think I'd like to save up to get the Ultimate 60, but like you said, hard to justify when I don't really need it - what did I just say???
Nice review, thanks.
One question. If you're carrying this light around in it's normal mode and a situation arises in which you'd like to have immediate full power (maybe you'd like to temporarily blind someone, have your buddy crash into a tree or something), is that possible? Or do you always have to start at 10 lumens and then step up?
Good review! :)
I've had an Ultimate 60 for three months or so now. It hardly ever gets used on the highest level, but it is neat to have that extra burst available. I probably wouldn't mind having an Ultimate 40 though. For about six months, I carried an Arc4, which was only around 35 lumens on level 1, and it was bright enough for most everything.
I definitely wouldn't settle for a Basic 40 or 60. The ability to program your individual preferences into the flashlight is what makes it so appealing to me. The secondary and minimum settings on my light are dimmer than the factory settings. I also like "force setting" off and "simple momentary" on, which is different than the Basic configuration.
Peter Atwood:
Yep, that's what I did :D
TOB9595:
Well, if I got the 60 lumen version, then I would regret not waiting a few more months because rumor has it that there's a 80 lumen version coming out...So I'm happy with my 42 :)
Ritt:
I carry with force setting off so it turns on at whatever level you had it on last. For example, if I'm going out at night, I just turn it on at max and turn it off. This way, when I use it next, it comes on at full blast. You can only do this with the Ultimate lights though.
Cerulean:
I have mine set up almost exactly like yours! The only difference is that I haven't changed the secondary setting yet.
