Ummm...aluminum or steel . Most knife materials are way more fireproof than YOU.
I wrap red oxide self-fusing silicone tape around many of my handles on fixed blades . More for grip than heat resistance: Melting point ~500 F . But even old dry wood will probably outlast your lungs .
Arsonist ? Seriously Mr "Professional " : Kindling temp of paper is 451 F (Also a Ray Bradbury book ) Unless you are continuously wet down or in one heck of a fireproof suit , then you wouldn't have to worry about the knife ! Plenty of firefighting equipment is made of stuff that melts and /or burns . eg the fire ax .I'll bet you can figure out what profession goes into burning buildings and why I would be asking about handle materials that are heat resistant if you think reaaaal hard!
Most epoxies break down about 400 F. However there are epoxies that have to be cured at that or higher temperatures . I'll bet that the aircraft in your avatar has some of those !! You might have to make your own epoxy/Kevlar or epoxy/carbon fiber .
If you have gloves that can stand the heat, I bet titanium is the king here (1670ºC or 3000ºF), even over steel (around 2750ºF depending on the alloy), aluminum (1220ºF)...
What exactly do you need a knife for in a fire? I have never used my knife in any capacity with regards to active fire. Doing firefighter tasks I use the screwdrivers on my multitool, very rarely cut seatbelts, and regular everyday cutting tasks all in everyday temperatures. BTW I use the seat belt cutter on my Res-Q-Wrench to cut seat belts. It isn't as koolaid as a rescue hook, but I don't care.I don t think that it is comfortable to keep in your hands very hot handle , even with gloves .........I think he need material for handle which hardly absorbs heat .......... insulator . Titanium absorb heat like sponge .Maybe wood is best for him , and not glued with epoxy , just rivets ........
Now that all actually sounds like a "pro tip" , voice of experience which usually beats out armchair theoretics .What exactly do you need a knife for in a fire? I have never used my knife in any capacity with regards to active fire. Doing firefighter tasks I use the screwdrivers on my multitool, very rarely cut seatbelts, and regular everyday cutting tasks all in everyday temperatures. BTW I use the seat belt cutter on my Res-Q-Wrench to cut seat belts. It isn't as koolaid as a rescue hook, but I don't care.
As far as materials go I like things that can be washed. Wood can absorb chemicals or get water damage. Wood handled tools have been going away in structural firefighting applications because synthetic handles are less maintenance. Wildland still uses wood handled tools but they aren't digging through burned synthetics and household cleaners. Cancer is a big thing in Fire these days.
Still , I honor and thank you for your service ! I had a close relative was a fire chief . He ALWAYS drove like he was" on the way to a fire" , right up into his 90"s .He was a hero to me .
