- Oct 14, 2018
Hope you all are doing well. I have two general heat treat questions and a more theoretical question. These are all AEB-L from .08 to .1. Any tips would be appreciated.
1. Do I need to make sure the blades are perfectly straight before sending to a professional heat treater? I know they will straighten, but will they straighten even if not straight when they receive? See pics, this is the worst bent one from this batch, probably close to .5" (12.75mm). Sorry it is so hard to see in pics.
2. Is this finish acceptable to send to heat treat? Last time I surface ground all of the blades before sending. But my platten is no longer flat so would have to get a new one or flatten by hand. But very little of the existing metal will be visible (or even there) on the finished knife, so seems like it might be a waste of time.
3. (Edit- see post 6, I do not believe it is a heat treating issue) I know this question gets asked repeatedly but I am going to ask again. What hardness should these knives be? It is close to 50 knives I will be sending and probably 45 are kitchen knives. My last batch was professionally heat treated to 61-62. I made one of the knives for my mom and after a month it was in the condition below. I said Sue, "what did you do to this knife? The tip is missing and it's chipped" Once I convinced her it WAS chipped and the tip WAS missing, her response was, "I've had knives my whole life and never had one chip or the tip break. There must be something wrong with it."
I am confounded what to do. I think the problem is that when sent for heat treating, the HRC is hit, but is it the toughest it could be for that HRC? Probably not. I would like to make them around 64 to maximize the steel, but if it is chippy for a non knife nut at 61-62, it might be really bad at 64. I may consider selling some of them and I think knife enthusiasts would prefer the higher HRC, especially for the Japanese style blades I am making. I think the solution is to heat treat them myself, but that would require running 220 to my garage, buying oven, buying foil, buying liquid nitrogen or dry ice, buying aluminum plates, straightening myself, buying hardness tester, and probably some other things I am forgetting. My girl will not be happy if I spend 2k more on knife stuff. Thoughts?
