- Nov 24, 2003
It was finally time to do the first heat treat in my new shop. While the Evenheat is coming up to temp with 2 O1 blades in it (about 25 minutes to 1469 -- I'd set 1475 and it kept oscilating between those 2 for the hold time), I tried out my used Ames #2 tester on an Rc 63 test block. First test showed 62, attempts to repeat that all went down, some into the 30's and 40's. Maybe I should bring this to the hammer in and have someone show me how to use it?
In the meantime I let the blades soak for 12 minutes then quenched them in 125 degree AAA and quickly (30 seconds to a minute of quenching time) stuck them in a 425 degree toaster oven for 2 hours.
After first tempering, a file would scratch them and they tested in the Rc mid-40's, this time the test block showed about Rc 52. I don't know if I've screwed them up or not
I'm really tempted to finish grinding them and put handles on them just 'cause I want to get something done! But maybe I'd better bring them along the HI too...
Any advice? This didn't go as smoothly as I was hoping for...
Dan Pierson
Dan Pierson
