- Jun 17, 2010
Hey everyone,
You may have seen my other post about attempting my first heat treat on 1095. If you havent, what I did was pre-heat the oven to 1500 degrees, I then put the knife in and let it bake for 15 minutes. I quenched in 1 gallon of Canola Oil and then Immediately tempered twice in a toaster oven at 350 degrees for an hour each time.
When I checked the knife after with a file it was hard. Now I have ground away more material and it seems soft. The edge is not as hard as it needs to be. Is there anything I can do before Christmas to fix this issue? I have access to an acetylene torch, should I just heat the edge and re-quench?
Thanks!!
-Ben
Thanks!!
-Ben
