If you are shorting coils with the pins/staples, you *may* be fine.
I would not risk it because I have had elements fail on my early HT ovens where there is contact, and it seems like a miniscule amount of movement/sparking/arcing/whatever may have been the cause: eroding away the element so that it gets slightly thinner, and therefore hotter, at the contact point until it burns out.
You need to bear in mind that the elements run on AC, so there is a relatively strong electromagnetic interaction between the coils at every high peak and every low peak of each cycle, followed by zero electromagnetic interaction as the Voltage crosses Zero, that will cause them to move against a fixed staple or, in the case of my failed elements, the tail end of the element where I'd wrapped it around the terminal post and let the free end touch the element. It's the same effect that causes transformers to "hum" at 120 Hz in the US and 50 Hz in Europe.
The failures on mine (16 Ga Kanthal A1) took between 1 and 3 years of semi-pro use. I later built some with 1/16" Kanthal A1 elements, taking doubled, twisted tails out through the walls and had no further problems. I stretch the coils to at least 3 times their tight-coiled length and use staples made from 0.8mm (1/32") Kanthal A1 over single coils, specifically to ensure that there is no shorting of coils.
Whatever you do, please let us know how you get on.
