I always worked on the basis that I'd do a proper writeup once I'd got it about right.
That's still the plan.
In the meantime, here are some pictures of what I've done to date, in more-or-less chronological order.
In the beginning, there was a guy on British Blades who had built a HT oven to Andy Gascoigne's plans
http://ftpforge.chez-alice.fr/HEAT_TREATMENT_FURNACE.pdf and was asking for help/advice on the electrics and control. He'd built a couple of nice grinders and lived only 1/2 hr away from me, so I went over with a PID controller and some bits I'd picked up over the years, got his HT oven working and took a good look at his grinders.
I was sufficiently impressed to build my own oven.
http://s667.photobucket.com/user/timmgunn1962/library/Toys?sort=3&page=1
That 1100 degrees is degC: 2012 degF. though I tested it to 1205 degC/ 2200 degF.
I did some testing with it to see how it could be improved: I'm a bit of a geek and I deal with temperature control systems and gas burners at work, so this was in my comfort zone. I had access to some useful measuring and datalogging equipment through work, along with some fairly high-end controllers. My boss was most impressed that I was prepared to spend so much of my own time familiarizing myself with the equipment.
The testing showed a number of things. One was that a ramp/soak controller could make a huge difference to the accuracy of the temperature control. Another was that a short output cycle (2 seconds) helped a lot as well.
The hunt was on for a decent ramp/soak controller at a sensible price. Auber Instruments did not have a presence in the UK, so the SYL2352P was ruled out, leaving the AutomationDirect Solo 4848VRE or the Omega CN7823. These last 2 are, so far as I can tell, the same controller with different badges. I buy whichever is cheapest at the time.
Mk1 was sold to fund the build of MkII.
http://s667.photobucket.com/user/timmgunn1962/library/MarkII Oven?sort=3&page=1
This used a Solo ramp/soak controller and seemed to do pretty well in my testing. It went to a young knifemaker here in the UK who agreed to be my test pilot.
Along with a few other things, his feedback was that it was not conducive to treating multiple blades. The overcentre catch needed both hands to close: pretty nigh impossible when trying to quench a blade and leave the others in the oven. The wiring circuit means that the green start button needs to be pressed after the door is closed. This takes a second or two at best and is easily forgotten: not great.
I was not going to change the wiring circuit. It's as safe as I can realistically make it. There's also a Residual Current Device (Ground Fault Circuit Interruptor?) that's not shown in the diagram. Over here, we have 240V mains Voltage to Ground and I make the ovens as a hobby (I'd quite like to make knives, but it's hard work and ovens are easier). They tend to end up with people I know and like, so I'd rather keep them alive.
I did have a rethink on the door catch though. I wanted one-hand opening and closing with enough closing force to compress the ceramic fiber blanket I use as a gasket.
I came up with a simple F-shaped catch that closed onto a pair of ball bearings (one was too narrow on its own) mounted on a shoulder screw.
It works surprisingly well.
I thought I'd build the oven so that it could be stood on its tail and used with a salt pot. Once I'd built it, I had second thoughts: molten salt and the safety of people I like did not seem to go together. The salt pot (2 1/2" schedule 40 type 310 stainless steel) occasionally gets dragged out from under the bench to use as a former for lining mini forges. It's never seen salt.
http://s667.photobucket.com/user/timmgunn1962/library/Mark 3 Oven with Salt Capability?sort=3&page=1
At about this time, I built a long one using 2 elements each rated at 3 kW and fed from separate mains outlets.
http://s667.photobucket.com/user/timmgunn1962/library/Sword-Length HT Oven?sort=3&page=1
and
http://s667.photobucket.com/user/timmgunn1962/library/Long HT Oven WIP?sort=3&page=1
I was rather lazy with this one and used 1" ceramic fiber board backed up with Calcium Silicate board for the roof. This meant that I could make the floor a full brick-length wide and bridge the roof with the boards, so I only needed to cut 2 bricks for the back of the oven. Everything else used whole bricks. The door was made from the boards.
The last one I built was the 22 1/2" long one. This came about after a discussion with a smith that started after a few beers at a hammerin and was revived some time later when sober. It's basically a normal HT oven with a door on the front and a removable back. I've made all my ovens except the first with separate control boxes, as the first one was a real pain to move. Everything plugs into the box.
The idea with this was that you would have 2 ovens and one control box. Once you've quenched, you plug in the other oven for tempering and avoid the wait while the first one cools down. If you want to make a sword, you bolt both ovens together and use the resulting 45" oven.
I made the first ovenand someone bought it, so I have not actually built and tested the full system.
http://s667.photobucket.com/user/timmgunn1962/library/Mark3 HT oven 23inch?sort=3&page=1
I've also messed about with forges and burners a bit. After building a few burners from scratch, I decided I was never going to get anywhere close to a proper industrial gas mixer for performance and adjustability so settled on Amal Atmospheric injectors from Burlen Fuel Systems here in the UK.
There's a heat-treat Propane forge setup that I've come up with that seems to give near-electric-oven temperature control, together with a reducing atmosphere to minimize scale formation, for long soak times on O1 steel. O1 is the most readily available blade steel in the UK (as Ground Flat Stock). Other steels tend to be hard to find here. I was trying for a cheap-but-good-enough HT setup. The video is from my test-pilot.
https://www.youtube.com/watch?v=1xvWkXBXY6U&feature=youtu.be
816 degC is 1500 degF.
