- Jun 11, 2006
While I was building my heat treat oven I had wondered if there was a way to have a viewing window. From my research it seamed like fused Quartz glass would be perfect because it will handle any temp we would use. The idea faded from my mind as time went by but today it popped back up. So I did some research and come to find out paragon and evenheat both offer Windows on there kilns. There window appears to be a single pane of Quartz.
But my thought was to do a double pane set up to isolate the heat better assuming that would help. I ran the numbers and it appears that air is quite a good insulator. To give you an idea how good an air gap insulates here it is compared to a K23 fire brick. Air has a thermal conductive of .0825w/mk @ 2000°. A K23 fire brick is .24w/mk @ 2000°. So as you can see air is much better insulator the the brick but the trick is to keep it from circulating and keep it still. I have some 1/4" thick round fused Quartz Windows that are 3.5" diamater that I think would be perfect for the job. My thought is to put one on each side of the fire brick and inset them flush to the brick. Then use high temp furnace cement to hold them in place. This would give an air gap that's very close to the same thickness as the brick which when comparing thermal conductivitys is a must.
So everything looks promising but there is one little catch that I'm wondering about. The window might be a good insulator but it does not insulate any radiated heat. Kinda the same thing as you feeling the Suns warmth standing inside your house. I wonder if that could create a problem in keeping the ovens temp even.
What do you think, it must have some merit if it's an option on kilns but I have never seen it on s heat treating oven per say.
