- Oct 22, 2007
I have had this happen the last few times I have heat treated 154CM. After the heat treat the blade has what almost looks like stains in the steel. It's difficult to explain and I don't have any pictures to help out with the explanation.
Immediately after removing the blade from the foil wrap it has a mottled appearance instead of an even gray coloring all over the blade. I have had this on some other steels but a quick run over a sisal wheel and it usually dissapears. The past few times I have used 154CM however, it won't buff or sand out. I haven't tried going really deep with the sanding but it does not appear to be only on the surface.
I have had it happen with my own knives and I heat treated a blade for a friend today and it happened with his blade as well. I haven't spoken to him yet but I believe the steel he used for this blade is from the same batch that I have been using. Is it possible that I have a bad batch of steel??
Here is my process for heat treating 154CM:
1-I clean the blade and handle with acetone and allow it to dry.
2-I wrap the handle with a piece of paper to burn off oxygen in the foil envelope.
3-I seal the blade inside a foil packet double folding the edges (this last knife I even placed the first packet inside a second packet to ensure it was well sealed.
4-Place it in the oven (Evenheat) and bring up to 1950 for 30 minutes.
5-Remove from the oven and plate quench (between two one inch thick aluminum plates)
I'm wide open to critiques, criticizms, suggestions, ideas??????
I have not had this happen with D2 or with ATS34 or 154CM in the past. This leads me to believe that the problem may be with the particular batch of steel???
Thanks,
SDS
Thanks,
SDS
