Hi, I am new here and just started making knives as a hobby. I have made a couple of knives out of 80CRV2 and learned a lot from the forums. Thank you everybody for posting so much information.
I am planning a new knife design for making Swabian spätzle and I am hoping to get some input regarding heat treating the blade. I plan to make the knife out of AEB-L and have found great info here about heat treating it. My question is more about tempering as this knife is not meant to be sharpened and should have some flex like a spatula for cake decorating. Maybe I should explain a bit how the knife will be used. Spätzle are traditionally made by scraping a noodle dough off a wooden board directly into boiling water. For scraping, either a dull knife or a special scraper is commonly used. The scraper is thin sheet metal with a rolled top for a handle. This type of scraper appears to be highly optimized for low production cost, but not really for the task at hand. The problem with the knives I have is that you end up hitting the rim of the pot either with the knife or your knuckles if you rest the wooden board on the rim of the pot. So I have sketched a knife design that gives more clearance and tested a plywood mock-up to see if it is comfortable and does not interfere with the pot. It seems to work well and I plan to make one out of 0.04" AEB-L.
My question is what temperature should I temper the blade at? Any advice would be greatly appreciated.
