- Apr 25, 2022
Ok, I have a heat treating question. I am doing some 1/8” stock and it turns out pretty warpy when I try to heat treat it, so I have been doing something sort of like a plate quench, but instead of aluminum I use wood. I do an oil quench first, so that’s not when it’s supposed to harden. After I oil quench it, I clamp it between two blocks and wait for it to cool between them so it’s straight before I temper it. Now my question is how much should I take off of the temper to account for the slightly slowed cooling between the wood? After 10-15 minutes it is still very slightly warm, so I imagine this would be an issue if I did a normal tempering cycle on it. I’ll check after this one is finished to see if it still skates a file, so if it does then I may just take a few minutes off the temper. If it doesn’t, then I may have to re-harden.
unfortunately this is a situation where I thought of an okay solution to the first problem, but I didn’t really think about if it would cause other problems. I think in an ideal situation I would go for metal plates, but I didn’t have anything on hand that would work for that. If I did, then I would probably just quench it then temper between the plates, so that would be no problem, but at this point I don’t have that. Any advice on this would be greatly appreciated! Thanks!
