- Feb 4, 1999
I am going to be receiving some D-2 in 5/32" thickness and these will be my first knives. I will use files and a Dremel. Iy was recommended that I do my own heat treat at home by Sean Perkins and wanted some input from anyone who has done this or had similar experiences...
Sean recommended using a Bernzomatic to take the edge to orange color, then quench the knife in water. He said this may cause a little warp, but it usually can be ground out. Sean then recommended tempering in an oven at 400 degrees for one hour, then testing the hardness, and repeating the tempering in several cycles until I had the hardness I wanted. How well do you think this will work?
I like the idea of being able to grind a knife and heat treat it at home, both from a financial as well as time and control aspect! I guess Sean uses a similar process on his knives of A-2 and even ATS-34, so it should work just as well on D-2. Anyway, any input or hints would be appreciated. I'll keep people informed as to how it works when I try it out (I'll start small with a couple small knives, of course, in case the results are sucky! ;-)
My Custom Kydex Sheath pagehttp://www.geocities.com/CollegePark/Lab/1298/knifehome.html
Palmer College of Chiropractic
On Two Wheels
On Two Wheels
