- Jan 1, 2026
Previously ive always either sent my blades for HT or have used a forge for simple steels. I now have an Oven and going to do my first batch of 80CRV2. I have the data from NJSB but a bit confused about something. It states not to put the blade in a cold oven. To put it in at Austentizing temp or close. At least thats how I see it. The instructions state to get the steel to temp and then soak for 5-10min.
My question is about that window of time between putting the blade into the oven which is at temp and the time it takes to get the steel up to temp. I dont have a way of checking the steel temperature. For reference it is a 12” blade at 3/16. Im guessing the soak time is after the steel has reached temp. How are you guys determining if the steel is where it needs to be before you start the “Soak” clock?
Thanks in advance.
Thanks in advance.
